Did you see the part where I said I was using a Haltech 2500 ecu, or do you not know what that is?The EEC and most hydro cams are designed for 6250.
If you're doing all of that on the stock electronics and no tune please post video of the
I would think you would know not to reply with a stupid answerI would think you would know the answer before you did all of that work ........
Valid question. Why would anyone go through all the trouble and not know what the block limitations are?I would think you would know the answer before you did all of that work ........
I'm using a blower, nitrous, 80 pound injectors, aluminum upper and lower, 70 mm throttle body, gt heads, long tube headers and a haltech elite 2500
what about the RPM? I think that read somewhere the max is 6000rpm, but I also read that some guys said with stock internals they are going as high as 7000rpm.I am doing 400hp now without my spray, I am asking because I'm trying not to blow the motor. I'm also trying to make up time by using better drivetrain ratio I'm trying to keep the original motor in the car but if I do blow it what bigger ford motor would be an easy replacement? and thank you for your courteous reply,I was told by a reputable tuner that with stock lower end that number is 500hp. Over that number the block is susceptible to splitting in half. At the water journals, I think he said, but don’t quote me on that location. I remember that number though because when he was tuning my car after the Vortech V3 install, and it put down 426 at the rear wheels, he did the math and said I was right at 500 at the crank, and didn’t feel comfortable turning it up any higher than that.
What blower (brand, model)? What boost level?I'm using a blower, nitrous, 80 pound injectors, aluminum upper and lower, 70 mm throttle body, gt heads, long tube headers and a haltech elite 2500
That’s more like .97cents.To re-iterate what @Noobz347 and @7991LXnSHO were asking. You have not given a whole lot of info on your combo. Those here for a long time have seen HUNDREDS of people ask this type of question only to vanish in the night. If you want good reliable help, please fill in the blanks when others ask clarifying questions on your combo. As also mentioned, pics REALLY help with understanding what you have.
So to demonstrate the blanks in information you have created and not answered one when asked for details:
What brand nitrous kit? What size of nitrous kit? Wet or dry system?
Aluminum upper and lower - I assume this is intake. Is it stock, Explorer, aftermarket or custom fabbed?
gt heads - Stock E7s, GT40s, GT40Ps, or others? Cast iron or aluminum?
long tube headers - what size - 1-1/2, 1-5/8, 1-3/4? It makes a difference.
haltech elite 2500 - I assume this is a stand alone ECU - Has it been programmed by a Pro on a dyno or by yourself in driveway or on the street? It makes a difference.
Like said above, if you want good reliable info, you MUST give better info and answer questions when asked. Not just move on to the next question.
Just my 2 cents.
And getting attitude, to boot.That’s more like .97cents.
if you have to pry that much info out of someone asking for help....you're paying them to tell them how to fix their sht.
