whats the best and cheapest way to put discs on my rear axle
  • Sponsors(?)
rbohm
SN Certified Technician
Apr 12, 2002
6,670
541
204
61
tucson,az
scarebird mechanical has rear disc brackets for sale, and they give you a parts list.
another way to go is get the rear brakes from a late model crown vic or grand marquis.
Decurion
353
Livonia, MI
With 31 spline axles, I suspect you may have the big bearings. If this is true, go with a set of Explorer brakes. I picked up a set from Taylor auto (a little drive from rochester) for $50, complete.
bnickel
5,640
51
lubbock, texas
Visit site
not necessarliy, you can put 31 spline axles in a stock mustang 9" housing, even the factory CJ mustangs with 31 spline axles used the same housing as a 351 2v mustang.
70vert
722
Bay Area, CA
If you want a parking brake that works, the internal drum of the Exploder/Crown Vic Wilwood kits can't be beat. I just switched to that on my EvM 3-link since there was no clearance for the Baer disc brake parking brake actuator, and the parking/emergency brake difference is amazing. Very easy to set. Heavier than a disc-only setup, but a functional e-brake is worth it on a street car IMHO. The insurance companies probably agree too. ;-)
Rusty67
3,749
36
109
Seattle area, WA
yeah but the explorer kit won't work on the early small bearing housings that all 65-73 mustangs came with either.
If the Explorer doesn't work then the Vic setup will. Only down side to the Vic setup is the rotor is a solid rotor instead of vented like the explorer. I've got an entire setup waiting to go on my 8" if I ever get time/motovation to work on it. Gota scrap my old daily driver before I start touching the 67 again....
bnickel
5,640
51
lubbock, texas
Visit site
actually, the exlporer has solid discs too. the one thing about the explorer kit that is different from CV brakes, besides the mounting flange, is that the explorer kit has the calipers mounted in a normal orientation both calipers on the same side of the axle centerline (front or back) whereas the CV discs have one caliper in front of the axle and one caliper behind the axle, other than those 2 differences the explorer and cv discs are almost identical functionally and aesthetically.
Rusty67
3,749
36
109
Seattle area, WA
Bnickle, looks like you straightened me out on that one. I just looked it up and they are solid in 2000. I thought they went to a vented setup by 2000 but I guess not.
The Vic setup has enough space in it to accomodate a vented rotor if you could find one that would work with the parking break setup. At least thats what I remember. I havn't looked at it in a while.
bnickel
5,640
51
lubbock, texas
Visit site
yeah and i thought i had found one that would work on eaby, but it mat have actualy been for a later model vic instead. i can't remember now though
JC6715
284
Hillsboro, Oregon
Not everyone is using a stock small bearing housing, I was just sharing my use and experience and a way to get relatively inexpensive brand new explorer type brakes.
bnickel
5,640
51
lubbock, texas
Visit site
that's cool, but you might want to mention that he would have to have the big bearing axles for those brakes to work is all. :nice:
ultrastang
1,092
Arkansas
www.ultrastang.com
The Crown Vic's rear rotors didn't go to ventilated discs until the 2003-present models. However, unlike the '92-'95 versions and then the '96-2002 C-V versions, the '03-up C-V discs are a different diameter, the calipers are different from previous models and both calipers mount in front of the axle housing, and the main cast caliper mounting bracket is configured for a housing end flange with a vertical bolt pattern instead of the more conventional horizontal pattern.
--In otherwords, it's not a [more or less] direct swap over like the earlier C-V versions. About the only solution I can see to mount the '03-up C-V brakes would involve cutting the 8/9-inch small bearing end flanges off, rotate them 90-degrees, and then weld them back on in order to mount the newer brake version. This would require a jig fixture to make sure the end flanges are true and square when being welded back onto the housing. That effectively takes out any simple bolt-on qualities of the '03 version.
bnickel
5,640
51
lubbock, texas
Visit site
hwat i meant was that i thought i had found an aftermarket rotor for the 96-02 Vic that was ventilated, but i haven't been able to figure out where i found it, though i'm fairly certain it was one of the Ebay sellers that specializes in brake parts. i'll keep looking and if i can ever find it again i'll post it here.
70vert
722
Bay Area, CA
good eye.
the description says "rear" but the reviewer mentions it's a front. Hard to tell if it has the drum brake surface inside of it.
Uhh, if you eliminate the word "cheapest" in this thread, just go with the Wilwood Superlite kit! :D:rlaugh:
Thread starter Similar threads Forum Replies Date
Busted07 What is the best (cheapest) place to get Mega Bite Jr's from? Fox 5.0 Mustang Tech 1
M What intake is best for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
D Whats the best intake for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
silverlx50 Engine What is the best way to lift lower intake off? Fox 5.0 Mustang Tech 7
Noobz347 The Last "What's the Best Sounding Exhaust" Thread - Mustang 2020 2015+ (S550) Mustang -General/Talk 2
Schnelly What are the best brakes for a 2008 GT? 2005 - 2014 S-197 Mustang -General/Talk- 8
ZephyrEFI Fox What To Do To Get My Mild SEFI 5.0L To Run The Best. Tune? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
E What are the best hp upgrades??? 97 cobra 1996 - 2004 SN95 Mustang -General/Talk- 4
killer5.0 Cowl hoods....who makes the best fitting/quality....what are you guys running? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
killer5.0 Satin paint...whats the best method...a single stage or a basecoat/matte clearcoat? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Casper93Fox Survey On Whats The Best Set-up. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
Real time recon Drivetrain Whats The Best Grease To Use ? Fox 5.0 Mustang Tech 6
B Buying Advice - What Year/models Are Best? 2005 - 2014 S-197 Mustang -General/Talk- 9
C What Mustang To Buy The Welcome Wagon 5
D What Intake Would Work Best For Me 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
Killa What Is Best Transmission Cooler For 4r70w SN95 4.6L Mustang Tech 2
ncaruso What Is The Best Selling Sports Car In Germany? 2015+ (S550) Mustang -General/Talk 0
H Tires--what Would Be Best? The Welcome Wagon 2
Crazytrucker74 Need Help... What The Best Differential Carrier? Fox 5.0 Mustang Tech 6
03TrueBlue Engine What Is The Best Cam 2005 - 2009 Specific Tech 2
90sickfox What's The Best Maf Brand For My Set Up ? Fox 5.0 Mustang Tech 1
Joseph Ghulmiyyah What Is The Best Fuel To Use In My S550 2015+ (S550) Mustang -General/Talk 5
Kdoggy What Is The Best Oil To Run In Y 04 Gt 1996 - 2004 SN95 Mustang -General/Talk- 13
Noobz347 What's The Best..... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
BKM48198 What Is The Best Throttle Body Size For Me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
danno Just Bought 03 Gt What's The Best Kenne Bell Sc Setup The Welcome Wagon 2
larrym1961 At What Temp Would Be Best To Set E Fan Controller To Turn On? Fox 5.0 Mustang Tech 6
jcgafford Seat Track, What Is My Best Option? Fox 5.0 Mustang Tech 2
99 FLA PONY GT Suspension What's Best Ride Quality Shocks & Struts For My '99 Gt? SN95 4.6L Mustang Tech 6
aesmith3 What's the best way to make the Stang shine? 2010 - 2014 Specific Tech 8
91 NytemareGT What paint is best to use on hood liner Fox 5.0 Mustang Tech 33
I What are the best budget-minded suspension mods?? 1994 - 1995 Specific Tech 6
greyfrankenstang What are the tried and true best options for trunk sound deadening? Mustang Sound & Shine All 12
D just curious what are best mods for 4.6 motors 1996 - 2004 SN95 Mustang -General/Talk- 15
boss_302 whats the best cam for 89 5.0 carbed motor in a 69 mustang Fox 5.0 Mustang Tech 1
ratio411 Engine What the the best intake gasket for E'brock heads? Fox 5.0 Mustang Tech 1
6 Engine What's The Best Rpm For 302? Classic Mustang Specific Tech 23
geneo4116 Whats Best Oil To Run,whats Ya Opinion 2010 - 2014 Specific Tech 20
geneo4116 Okay So What Is The Best Exhaust For No Drone Inside Car 2010 - 2014 Specific Tech 31
Venom351R Exhaust Whats The Best Way To Neck My 3" Prochamber Down Into A 2.5" Catback? 1994 - 1995 Specific Tech 8
Copentreygen5oh What are the best hid's 2010 - 2014 Specific Tech 11
IH8BOWTIES What's the best fuel pump? Fox 5.0 Mustang Tech 3
Justin81 What's the best way to remove pilot bearing? Fox 5.0 Mustang Tech 12
foxbodymike87 What cam goes best with gt40p heads? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
T What's the best option for projector HID lights? 2005 - 2009 Specific Tech 0
65fastbackresto What is the best forum for refinishing? Classic Mustang Specific Tech 2
Mirrahasmycar New engine time 00GT , whats the best solution SN95 4.6L Mustang Tech 19
D What is the best Tuner SN95 4.6L Mustang Tech 28
comporange2004 whats the best gears to put in my 2004 v6 3.9 automatic SN95 V6 Mustang Tech 0
shaunspengler what are the best parts at ad up to $1500 1996 - 2004 SN95 Mustang -General/Talk- 13
