I have been fiddling around with my car since I stuck in my new 3g alternator. I had too much amperage going through a 10AWG (the wire off of the ground battery cable to the ground wire on the driver side, near the battery tray) and caused it to melt and caused the car to shut off. I then read online that I was suppose to have a 4AWG wire coming off of the engine block to the ground on the driver side (Near the battery tray). Which I did not, until now. So now I have both, however I am afraid that something like that will occur again, so before I install the battery I want to know what I should expect.
Let me state, I bought a cheap fuse holder, the plastic that the fuse and wire connects to, fell off and caused the cable from the alternator to touch a bolt, which was attached to some metal on the car, causing it to ground out. I fixed that, but I then found out I was missing a ground cable, which my situation would not have happened, if I had that cable.
So I installed a new fuse holder (same cheap one, till a better one arrives) and taped the crap out of it. Replaced the negative side battery cable, and the attached 10AWG cable. Added a 4AWG ground cable. So now, I am checking continuity. I am a bit confused on what the outcome should be.
I attached one probe to the positive post on the alternator and one probe to the positive battery cable, clear beep!
I attached one probe to the back of the alternator and one probe to a random screw that held the fuse holder (no longer in use), it kinda beeps, but I have to constantly move the probe on the screw for it to beep. Should it do that?
I attached one probe to the positive battery cable and one to the negative battery cable, clear beep, is that right?
I attached one probe to the positive post on the alternator and one probe to the negative battery cable, it is a clear beep, is that right?
Also, I did move the yellow wire from the wiring harness to the positive post on the alternator, as a alternative wiring solution.
Thanks for the help guys (sorry for the long post)!
Also my mustang is an 89 5.0L 5-Speed.
