Your mean is replace rocker studs like D.Hearne? Or?
Could you suggest Me what Can i do?
Regards
Regards
Max 500 miles, i ran.
Could you give me some details about problems?
My camshaft is COMP Cams K31-242-3 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com
And if i need to change studs, you can give me the summitracing item codes, that will be really great for me.
HERE ARE THE STUD NUMBERS: CCA-4504-16. THESE WILL NEED TO BE INSTALLED MY A MACHINESHOP. THE STOCK ROCKER STUDS ARE PRESSED INTO THE HEADS AND BIGGER AD MORE AGRESSIVE CAM PROFILES THAN STOCK TEND TO WORK THE STUDS OUT OF THE HEADS AS THERE'S NOTHING THAT POSITIVELY HOLDS THE STUDS IN PLACE, OTHER THAN FRICTION
You can give me the summitracing item codes, that will be really great for me. Some of rocker arms, i have to change my valve cover. If we need to, i change this with tall ones.
ROCKER ARMS : THESE AREN'T THE BEST (IN SOME PEOPLES OPINIONS) BUT THEY ARE GOOD ROCKERS, CRANE ENERGIZERS, SUMMIT PART NUMBER CRN-11746-16. THESE ARE BASICALLY THE SAME ROCKERS FORD USED ON THE 90'S COBRA 5.0'S I'M BEEN RUNNING A SET ON MY 89 RANGER'S 5.0 FOR ABOUT 8 YEARS NOW, I BOUGHT EM USED WITH ABOUT 100,000 MILES ON EM AND THEY SHOW NO SIGNS OF WEARING OUT
I'd like to install Limited Slip Differentials. There are two option.
One is EATON
Detroit Locker 912A616 - Eaton Detroit Truetrac Differentials - Overview - SummitRacing.com
Other one is AUBURN
Moser Engineering 542059 - Moser Engineering Auburn Pro Series Limited Slip Differentials - Overview - SummitRacing.com
Which one is better?
JUST ME, BUT I'D GO WITH THE DETRIOT LOCKER. THEY DON'T HAVE CLUTCHES THAT WEAR OUT.
And 3.25:1 Ratio gear (i dont want to loose my top speed more)
Strange Engineering RS07880325 - Strange Pro Street Ring and Pinion Sets - Overview - SummitRacing.com
Regads,
Musa
If you are putting screw in studs in a stock head, guide plates are not necessary. They are only $25 bucks and when machining for the studs they can be added if you like.
I have original heads (1965).
If guides plates are applicable for 65's head and better than install studs w/o guides plates i will buy.
Suggestion?
