Which Is A Better Investment?
  • Sponsors(?)
JordanB21
804
27
29
25
Killeen, Texas
340 for a near 4G crate? You could stroke out your engine and get a full top end for that much, and if you wanted, bore it out to a 306. Same deal. More power.
I wouldn't bother with that crate, bolt ons are cheaper, and more effective(when we are talking about between a 302 and 306), plus you can piece it together.
ratio411
3,870
73
109
Pensacola FL
If you have the skills or are willing to learn the skills, building your own is always cheaper.
The cost of the crate engine is half parts and half labor, and ALL retail.
If you shop around, you can get the parts for less, and do the labor yourself.
But it is only a deal in the end if you do it right though. It's not hard, but takes patience and determination.
Vaz88GT
264
27
38
I realize its overpriced and i'd rather build it, I just wanted to know if its worth putting money into a 150k mile engine, or would it be better to just throw a crate in there.
I guess once I get it taken apart I can judge if its worth it.
Reactions: ratio411
ratio411
3,870
73
109
Pensacola FL
Exactly!
150k is nothing if you are letting a machine shop clean everything up.
Once they machine the metal surfaces, they are like new, assuming the shop checks everything for anomalies like cracks or warpage.
Reactions: Vaz88GT
Vaz88GT
264
27
38
Exactly!
So what exactly would I need done? Other than checking for cracks and boring the block to a 306?
ratio411
3,870
73
109
Pensacola FL
Well, I just had a 5.0 in the machine shop.
He checked the block for:
Deck flatness, was fine.
Bore, ended up going .030" overbore to clean it up.
Line bore, was fine.
Boiled the block, which then requires new cam bearings and freeze plugs.
Checked for cracks.
Heads:
Valve job
Checked the guides, they were fine.
Checked the heads for flatness. Milled .018" to get out damage from a blown head gasket (aluminum heads).
Check for cracks
New seals
Retapped some accessory holes, again due to soft aluminum.
Rods:
Cleaned, pulled old pistons, installed new.
Checked for straighness, fine.
Checked bores, fine.
(I have had rods that didn't check out, and needed resized. It is not common, but does happen.)
Crank:
Clean
Check
Ended up grinding it .010" on the mains and .010" on the rod journals.
I have the crank installed now, and it can be spun in the block with a slight push of the finger!
(No rods, no cam connection, and torqued to 70#s)
I hope the rest if the build is just as perfect.
ratio411
3,870
73
109
Pensacola FL
I think so far we have spent about 500 in parts, and the labor at the machine shop was a hair over 500.
So if you build it yourself, you are looking at roughly 1000, not including your aftermarket speed parts.
That covers new gaskets, seals, plugs, machine work, pistons, rings, oil pump, bearings, and to be fair, the parts 500 included some ARP fasteners and oil pump drive. Also gotta figure a couple hundred less on machine work if you go with new aftermarket heads.
So you could probably do better than $1000 for the foundation of the build.
Thread starter Similar threads Forum Replies Date
90lxwhite Better investment, rear control arms or sub frame? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
U 289 or 302, which is better to invest in to rebuild? Classic Mustang Specific Tech 12
DarthStang2003 Which are better brakes to upgrade to on an ‘03 GT with some bolt on mods! 1996 - 2004 SN95 Mustang -General/Talk- 1
Z An even better tool for Mustang headrest removal!! SN95 4.6L Mustang Tech 0
mustang70 Better way to adjust speedo? Digital Self-tuning Forum 1
MrPerfect2 Fox My stock 91 GT performs better on 87 gas 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Angelnava81 Which is better 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 43
M I have a 85 Foxbody I am getting a 427w roller and I don't know what would be better Supercharger or Turbo? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Stanger93fox Wondering if the 373 rear gears are better for p 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
Tubbster66 Better speakers, better sound? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
Jinx Need Better Tires 1996 - 2004 SN95 Mustang -General/Talk- 6
CarMichael Angelo Some Days Are Better Than Others.. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
justin82 Drive Better? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
T Better Sound! 1996 - 2004 SN95 Mustang -General/Talk- 9
92Apocalypso Better Choice Of These 2 Suspension Kits From Lmr 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
Noobz347 Resource Discussion Fuel Flow Forensics - 33 Views And Zero Downloads? Better Not Be Any "what Pump To Run" Threads :p 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
red05bullitgt Would The S-197 Look Better As A Full/true Fastback ? 2005 - 2014 S-197 Mustang -General/Talk- 6
8 What Year Did Ford Start Using A Better Sterio? 1996 - 2004 SN95 Mustang -General/Talk- 7
MrFoxNutCase Ooops I Did It Again (2 Notches Better Than 1?) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
splogan Money Better Spent? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
Better beater Better Beater 93 Build Fox 5.0 Mustang Tech 19
bloodmechanic New Intro, Better Attitude The Welcome Wagon 2
X Better Fox Ride? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
Curtissickk Tuners Better Than Bama? 2005 - 2009 Specific Tech 2
mpeach1976 What Would Be A Better Gain For The Money? 2005 - 2014 S-197 Mustang -General/Talk- 8
T Which Is A Better Buy? 2005 - 2014 S-197 Mustang -General/Talk- 5
JhMustangGT03 Cleaned The Muck Off My Wheels...better! 2005 - 2014 S-197 Mustang -General/Talk- 5
lawman834 Iso A Better Forum... The Welcome Wagon 2
from6to8 She's Running Much Better After Blown Intake Gasket Fix....but I Still Want To ...... 1994 - 1995 Specific Tech 6
90lxwhite Would 6 Spd Trans Give Me Better Od W 3.73 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
85 mustang lx Intake Question Want Better Flow Fox 5.0 Mustang Tech 16
MRaburn One Of The Better 2015 Ford Mustang Realistic Renderings StangNet Site News 0
1 Turbo Vs Supercharger..which Is Better? 2005 - 2014 S-197 Mustang -General/Talk- 15
SterlingGreyGT Better To Build Or Buy Complete? 1965 - 1973 Classic Mustangs -General/Talk- 11
ScottyG00GT New 5.0 87 Octane Vs. 93 - Overall Runs Better On 93? 2005 - 2014 S-197 Mustang -General/Talk- 13
WhiteCobra95 Engine Bbk Vs. Edelbrock Throttle Body For Sn95 5.0, Which Brand Is Better? 1994 - 1995 Specific Tech 15
NIKwoaC Why Boost Is Better Than Nitrous. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
runningONfumes Heads... Good, Better, Best. SN95 4.6L Mustang Tech 12
W 94 cobra run rough, cuts off, but runs a little better with MAF unplugged 1994 - 1995 Specific Tech 38
W Engine 94 Cobra, runs real rough. But runs better with MAF unplugged Fox 5.0 Mustang Tech 2
B Which S197 set up do you like better? 2005 - 2014 S-197 Mustang -General/Talk- 10
Z Engine 351W - Max Lift? Which Heads Are Better? 1994 - 1995 Specific Tech 7
billison Better than you used to be... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
from6to8 Car Doing Better;if I Get This Cel Worked Out I Think........ 1994 - 1995 Specific Tech 10
V8_Kind_Of_Guy Aod Or 4r70w? Which Is Better? Fox 5.0 Mustang Tech 29
boostfrk Which Hood Would Be Better? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
StangYellow Need A Better Cam For Supercharged 306 Fox 5.0 Mustang Tech 11
ReefBlueHatch Does More $$$ Really Get A Better Throttle Body? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 51
stangboy Which Is Better Lightning 90mm Maf Or C&l 85mm? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
sixt9coug Install front spoiler.... better MPGs? 1994 - 1995 Specific Tech 8
