SVO calipers are 8370mm^2 of piston surface area. 99-04 CObra calipers are 5152mm^2. Rear calipers are 4580mm^2 and remain constant.
SO swapping the SVO fronts to the cobra calipers is a 25% reduction in total surface area of all the calipers.
1 1/8" SVO is 638mm^2 of area. The 1" bore MC is 507mm^2. That;s a 20% reduction. That's as close as you are going to get.
1993 cobra, and 85 lincoln town car both have 1" bore MC's, but the town car MC will be an easier swap since it's SAE threads. However, the SVO MC might need an adapter since it appears one line is a different pitch. You might need to swap it with a standard GT line. Unfortunately i don't know this info completely, so you might have to do some legwork
Hey guys you've helped me tremendously in the past and hope you can help me again. Basically I'm doing the 11" brake upgrade with the 73mm lincoln/svo calipers. I'm gathering all the parts and I've read the Matt GT web page a million times. Here is my question: on the web page it says all...
vb.foureyedpride.com
