Ok guys so I had a miss problem
http://forums.tccoa.com/showthread.php?t=107396
Thought I had it licked, then today on my way home from work some wierd things happened. First the car was missing like before, at least it feels like a miss acceleration is choppy and at idle it sure seems like one cylinder isnt doing its part. So I drive on pissed off and then a few blocks later it starts running fine. So i do a quick sweep of my guages and my temp gauge is pegged out, well over 240. Its 3 degrees below zero and the car had been running for 3 minutes tops no way it got that hot that fast so I figure I have a bubble in my coolant no biggie my buddy said he bled the coolant after we got my water pump leak fixed well maybe he didnt, whatever. So I get home and take off the rad cap no pressure release or hot coolant. The radiator is full but the coolant is not hot at all. BTW I know its a bad idea to take the cap off a hot coolant system. Maybe my t-stat is messed up but I replaced it when I did the head swap, so I'm not ready to pull the trigger on that one
