So long story short my cousin John has been developing his own series of gauges over the past 2 years. Well they are finally ready and i became test dummy for first set to be put in a car. The 5 in tach works flawlessly (after alot of software changes) with the ingnition in the edge mustangs, and also has its own built in nitrous control and traction control and water/meth control. The water temp gauges controls the fan with its hi/low settings that are user programmable. The air/fuel gauges can be set to be either narrow/wideband with the push of two buttons on the gauge. Mine is a narrow until i can afford to order a wideband sensor and unit. He a full lineup as well as boost gauge that doubles as a boost controller. Each gauge has 7 different programmable colors, Hi/low settings, Pointer brightness settings, dimmer settings for dimming them when headlights are turned on. Backlight brightness,peak playback and more all user programmable. The tach features its own built in shift lights. The black spots on the tach when reved in the low zone will light up yellow as you rev higher. Once you reach the programmed Hi level all the lights light up red( this brightness also changeable). Well so you guys can see what im talking about here is a pic of them in my car.
