what I did on my saturday
Poisoned Pony
286
46
Citrus Heights, CA
Zex adjustable kit installed on my ride. I set it for the 100 shot. Next up, I have to add the purge, blowdown tube, bottle gauge and heater :D
looks very nice very nice. I'm debating on getting a plenum/tb looking at the trick flow how is the one you got on your car? would you recommend another brand?
if you don't mind the higher asking price or can find a deal on a used one, I'd go with the Accufab setup. I went with the Trick Flow setup because it's satin finish goes with everything I'm doing on the GT
SVTLaser - lololol
I installed my nitro right at the elbow bend, so the fuel will be pulled directly into the throttle body instead of spraying/splashing on the 90 degree bend. My instructions said to place about 6 inches from the TB. That ZEX setup looks nice, I like how they have the computer control unit to handle both input/output lines. I went ahead and slapped on the Typhoon intake manifold after some porting/flash removal work just to be on the safe side. I don't want to turn my hood into a shaker quite yet.
D@mn... That looks good Matt. Chad did some clean work. Where is Amazon doing there tuning session @?
The GT is gonna be pretty nasty now. Looks like you will be giving some of the local Termi's a run for there money now....
Chad's wiring is the ****nit :D They're doing it down at Jeff S' shop in San Jose, SVTP thing.
Next I'm gonna step down to 3.73's. I would of done better against that 350z had it not been for my gears IMO
When I did my buddies I put it on the bend but he forgot the silicone. So I used JB weld and told him to get the paint in whatever color he likes then I will finnish sanding it and paint the whole pipe with the nut in place so it should look a little cleaner :shrug:
