When I'm at the track, really hard cornering will cause my fuel gauge to read almost empty. For example, I can be going down a straight-away and it will read "240 Miles to Empty". Then, when I throw the car into a corner (and I corner VERY hard) it will cause the needle fuel gauge to go down to empty and the display will read something like "3 Miles to Empty". Obviously, the hard cornering is causing the gas in the tank to slam from one side to the other.
Turning the car off/on again will reset the gauge and display. I have already had TSB 06-10-13 performed on my car, which replaces the fuel sending units. Has anyone else experienced this issue? What else would be causing the car to do this? Is there some sort of a "float" that is getting stuck with hard cornering? I'm at a loss.
Thanks in advance..
Thanks in advance..
