Im interested in seeing what have to say about this... i've often wondered in the past if im wasting my money on 93![]()
Your car is designed to run on 87. You will not benefit, and probably see a decrease in performance if you up to 91-93 octane. Unless you have a timing adjuster, or a custom tune with more timing, stick with 87.
Theres the answer. I did notice a HUGE increase in power from a 93 octane tune.
A good tune will work wonders for any car.
But i still swear i noticed a little increase in performance when i was 95% stock... I guess it was just mental![]()
I would make sure that the car does not have any aftermarket tune on it, first. Detonation can due damage to a motor. If you run 87 and don't hear any detonation, or pinging, you probably have a stock tune and should keep the 87 in the car until you get a custom tune.
I have a custom tune... and oh wait... a 66mm turbo. haha forgot about that.
I was just refering to when I was mostly stock.
You should know that owning a FI car!
The guy I bought mine from used premium so I have been too. Is there any harm in doing so? Any benefits? The owner's manual said it was designed for regular and using premium isn't recommended. Just wanted some opinions. Thanks in advance.
i run 93, because of my tune/compression
so shell is a pretty good gas? i used mobil for a while, but it sucks, lots of corbon deposites, in my and my dads motor, we pulled my dads heads off a few years ago, and the exhaust ports were filled with a thick coat of carbon
but that may just be my imagination. In reality, I think any of the major brands are probably fine.
