Ok assuming it is a 90 there is 2 solenoids, one on the fender and one on the starter. sounds like you either have the remote wire directly hooked to power (have the remote wire hooked to battery post on fender solenoid) or have the main power cable hooked onto the wrong post on the starter. The big question is is the starter motor only spinning or is the starter actually engaging and turning the engine over. The wiring should go as follows, Battery to positive side on fender solenoid, large cable from fender solenoid to large post on the starter solenoid from the positive side of fender solenoid(same spot as battery is hooked so constant power). Then from the small post on starter solenoid to the opposite on the fender solenoid. Hope this helps.
