Imported Item
Imported Item
  • Ryden Ryden
  • Apr 23, 2013
  • 0 Comments
Harbor Freight specials. Lmao! And the A pillar mount is suppose to be for a 95 & up stang. I retro fitted it. Turned out very close match.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 23, 2013
  • 0 Comments
Tach in a coil mount. looks great on my steering column.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
A well needed up grade. No im not really a fan of short throws least i haven't found one i like. If you are using this particular Hurst you have to use your old hardware. ie. the big rubber bushing on the outside. doesnt explain very well. But once it was installed right it makes a huge difference.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 3 Comments
Yeah i know i need bigger air cleaner and yes those valve cover have been changed. Notice the HEI style distributor.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
Its so beautiful!!! Glimmering with potential. Its basically a 4150 style Quick Fuel.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
So after the gear swap it was time for some better fuel delivery. And we're not talking a edle-bore.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
While it was out i also threw on some SVE uppers and lowers. With the new 3:73s finally can have some real fun now.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
Ready for install and went ahead and painted dampener for some needed contrast.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
Almost done painting here. Also took the liberty of installing new outer bearing and seals and having a another friend of mine weld axle tubes to the housing. And for you trolls out there axles slide in and out just fine my friend does this professionally.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
With the help and guidance from a good friend. I would start the tear down.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 21, 2013
  • 0 Comments
My first rearend build. With all my control arms sprayed over night this removal was done in under an hour. This being the second time I've done a removal. On any vehicle.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 2 Comments
Do it right the first time and you'll get this result. Better than the magazine look. A year later still looks like this.
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 0 Comments
Take your time and use water. And don't use the metal zip strips. Use the bailing wire to tie the ends down. The steel strips look cool but had a Hell of a time getting them tight. After you cut them to be clean they will cut you up next time you do a plug change!!!
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 0 Comments
Biggest pain in the ass. Take it to a friends house and bring your wife to help cause your going be doing this all day. lol
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 0 Comments
King cobra clutch kit. Firewall adjuster, quick throw quadrant and new cable. Very noticeable performance upgrade. also affordable
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 3 Comments
Out with the 4 an in with the 8. A budget boss 302. H beam rods, 351 cam, efi 351 heads, boss style flat top pistons. Not the cheap ones!!
Imported Item
Imported Item
  • Ryden Ryden
  • Apr 18, 2013
  • 0 Comments
"In the beginning there was" a 1989 coupe 4 banger 5spd and then......
Ryden
modifications of the last 3 years
What an awesome community!
Album information
Album owner
Ryden
Date created
Item count
17
View count
984
Comment count
Rating
0.00 star(s) 0 ratings
Album privacy
Ryden
Can view media items
Everyone
Can add media items
Album owner only
