17x10.5
Discussion in 'Mach 1' started by 32valves, Jul 20, 2007.
  1. 32valves New Member
    Apr 20, 2007
    Message Count:
    42
    I'm looking to buy a set of 17x10.5 FR500's for the rear and 17x9 for the front.
    Do I have to worry about any rubbing?
    Also what is the widest tires i can put on 9 and 10.5in?
  2. GT98 New Member
    Feb 7, 2003
    Message Count:
    195
    You don't have to worry about any rubbing with a 10.5" wheel. The widest tire you can go with is a 315 before you start running into any rubbing issues with the exhaust.
  3. Mach1Run New Member
    Jun 25, 2004
    Message Count:
    417
    17x9 i have 275s on front, maxxas something tires
    17x10.5 i have 315s on back no rubbing, sumitomo htrz tires
  4. freakshow12 New Member
    Sep 6, 2007
    Message Count:
    I run 315 555R's on my 10.5's with no issues. I am on pro kit springs as well
  5. grey03mach1 New Member
    Oct 12, 2007
    Message Count:
    Same here with the 315's and I have the H&R SS Kit.
  6. DOHC otto Member
    Oct 11, 2007
    Message Count:
    247
    Also watch your quad shock, if you want to go bigger than 315. They are tapered from factory the thick end is toward the rear of the car and of your wanting to run a 335 you flip it to where the narrow end is toward the rear and the thick end closet to the caliper and rotar.
Share This Page
