1975 Mustang ll Wiring Help Needed
Discussion in 'Mustang II' started by Hawkk72, Nov 27, 2007.
  1. Hawkk72 New Member
    Dec 13, 2006
    Message Count:
    47
    I replaced my alternator, hooked up the negative battery cable and the fusible link going to the positive side of the starter solenoid immediately fried. Could something be wrong internally in the new alternator to cause this? Where does that fusible link wiring connect to besides the soleniod? Is a replacement available?
  2. suki243 Member
    Dec 19, 2006
    Message Count:
    696
    so you didn't turn the key or anything, just as soon as you connected the negative battery cable, the fuse blew?
    I'm not 100% sure but check to see if a wire from the positive terminal is touching the body somewhere.
    I'm from the classic section and i recently replaced my alternator so this thread caught my attention, So i'm not sure how the 75 looks/ works or how its wired. but normally shorts are caused by that. and i believe replacements are readily available at the local pepboys or autozone or something... between my new 110 amp alternator and battery i have a 175 amp fuse...
  3. COBRAIIW New Member
    Apr 26, 2003
    Message Count:
    598
    Does the large cable on the alternator come in contact with any part of the alternator casing?
    Could have happened inadvertantly.
  4. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    Would this be the fusible link powering the car or would this be the fusible link going to the alternator?
    If the link going to the alternator then something in the alternator is bad.
    If it's the car power link ... OOOooo, that sucks nuts. I hope it shorted out before it got too deep into the loom.
  5. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    Yep, the main lead could have rubbed through, or the insulation could have gotten brittle and exposed a patch of wire. Or, Or, ... stud on the alt could be grounding, or ...
  6. COBRAIIW New Member
    Apr 26, 2003
    Message Count:
    598
    Any luck yet?
Share This Page
