1989 2.3 mustang
Discussion in '2.3L (N/A & Turbo)' started by tararod, Jan 12, 2009.
  1. tararod New Member
    Jan 12, 2009
    Message Count:
    My mustang turn signals are not working but the hazard lights are working but not hazard flasher in the fuse panel
  2. Saleen8786 New Member
    Oct 8, 2003
    Message Count:
    225
    be more specific, you dont have blinker lights on your cluster? Or your turn signals dont work at all totally?
  3. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,752
    78
    There is another seperate flasher for the turn signals. It is located under the dash, somewhere not too far from the fuse panel. It has only 2 wires going to it and just hangs inside the dash area, not really attached to anything. Replacing that flasher should solve your problem.
  4. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Turn on your hazards, walk around the car, and make sure you have no burned out bulbs, first off.
  5. Hovergirl New Member
    Jan 12, 2009
    Message Count:
    I just fixed the same thing on my 93. It was just the flasher unit total cost $3.37 and 5 minutes. It was under the dash next to the console.
    Hovergirl
  6. Saleen8786 New Member
    Oct 8, 2003
    Message Count:
    225
    on my 5.O its a big metal circle that just plugs in,shouldnt be hard to find at all.
  7. fess40 Founding Member
    Nov 17, 2001
    Message Count:
    219
    I second the burned out bulb, Red_Lx recommended. Just make sure the new bulb is in tight so it doesn't fall out inside the light fixture. Ask me where I keep my spare turn signal bulb!
Share This Page
