1995 convertible 5.0????
Discussion in '94-95 Talk' started by slayerripkdc, Sep 3, 2006.
  1. slayerripkdc Active Member
    Jun 4, 2003
    Message Count:
    1,238
    10
    48
    brewster ny
    Hey I am new to the sn 95 thing....... I had 3 foxes before and I really wnated an sn 95 convertible. So I would appreciate it if I can ask some questions.
    First, how much does a 95 convertible weight
    Second, are they capable of running in the 14's with a full exhaust and 4.10's?????
    Third are they less maintance then an 87-93 fox body???
    thank you guys so much
  2. mo_dingo New Member
    Aug 27, 2003
    Message Count:
    3,031
    Tucson, AZ
    Mine weighed 3480 with everything factory in it.
    If you have a good track near sea level, I am sure you could get into the 14's w/ gears and exhaust, no problem.
    Maintenance is pretty much the same. It has new components like the electric fan, upgraded alt, new dash setup, etc which can add to the potential problem list.
    For what it's worth, The 2 parts I have had to replace on the car were the IAC valve, and the LPS (a/c). And the IAC only went bad b/c I cleaned it, lol! But I haven't passed the 90k mile mark yet, so i know it will grow with time.
    Hope that helps. Good luck in your searching.
    Scott
  3. Pokageek Active Member
    Jun 11, 2005
    Message Count:
    2,906
    46
    MA, USA
    3450
    Yes
    Although I have ALWAYS liked that older body style (and owned one) The tops in the 87-93's had a tendency to not clamp as well in wind and the 87-93 had a lot more squeaks and rattles. Only squeak in my sn95 was that dam plastic around the shifter that I filled with "great stuff" now no more squeaky. ;)
Share This Page
