2.3 engine life??
Discussion in '2.3L (N/A & Turbo)' started by 12Pack, Mar 5, 2008.
  1. 12Pack New Member
    Jun 4, 2005
    Message Count:
    55
    Ok so I found this 5spd 2.3 91 lx for sale... $500. Everything looks clean but it has 220k miles.. And that is hella high and I was wondering if I should get it im only using it to drive back and forth to work .. less then 5miles a day. Everything was kept up all the time oil changes, plugs/wires, no leaks no knocks or smoke. What do you think and how much life is left of this fox?
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    If it runs good and doesn't make any weird noises, it should be fine. They'll last a long time.
  3. tim_lemmy New Member
    Dec 13, 2007
    Message Count:
    95
    my 93 lx has 189k miles on it and i've only had superficial probs with it. alternator and such
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    We went 11's with one that had 320k miles on it...that tell you anything?
  5. fess40 Founding Member
    Nov 17, 2001
    Message Count:
    219
    Mine only has 120,000 but it still idles smoother than anything I've owned before.
  6. KH! New Member
    Nov 17, 2006
    Message Count:
    44
    Those motors commonly poop out after around 240K and even then they still run, just slugish, so for 500 and your only driving less than 5 miles to work? Get it, by the time that thing starts to have problems you should have the money to fix it.
  7. 65ShelbyClone Founding Member
    Sep 9, 2000
    Message Count:
    4,527
    66
    +1
  8. rd Founding Member
    Jan 12, 2000
    Message Count:
    3,259
    58
    Yes, buy it, they last a long time with decent maintenance. I have one of those $500 specials, and its run fine for 5 years.
    Oil changes, and check the cam drive belt.
    Then get another one for cheap and go again, or redo the one you have.
  9. red25th_4banger Founding Member
    Apr 10, 2002
    Message Count:
    90
    Stinger is absolutely right I've seen 2.3's with 400 000km on them (240k miles) that still had perfect crosshatching on the cylinder walls!
  10. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    my daily driver that Stinger and I just painted has 286k on it and I intend to take it on 2000 mile trips anytime I feel the urge. It doesn't even really matter if they've been driven hard the engines will still outlast everything else.
  11. poor4bangr New Member
    Nov 3, 2006
    Message Count:
    15
    mines got 220 no problems here nothing to big
  12. tim_lemmy New Member
    Dec 13, 2007
    Message Count:
    95
    i know a guy that ran one on 3cyl while trying to blow it up and couldn't do it. it had 280k on it and he still has the block it's in a ranger now
  13. Billy88LX Founding Member
    May 1, 2001
    Message Count:
    156
    i have one with 230 000km and runs strong. It doesn't use a drop of oil.
Share This Page
