2.3 transmission
Discussion in '2.3L (N/A & Turbo)' started by 93lx2.3t, Oct 3, 2005.
  1. 93lx2.3t New Member
    Sep 25, 2005
    Message Count:
    what transmissions will bolt up to the 2.3. i have been told that the aod will bolt right up. im in need of a news trans as the lovely little a4ld is dyeing. i would prefer not rebuilding it but swaping with something other than a t5 right now, that can hold up to some abuse
  2. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    the AOD will NOT bolt up, the only options for autos is the A4LD, and the C4 which has no overdrive and the bell housings are tough to find. the best bet is to have your auto rebuilt with explorer parts (it you must have an auto) or do a t5 5 speed swap. I swapped in a 5 speed and would never go back to an auto.
    Dr.
  3. 93lx2.3t New Member
    Sep 25, 2005
    Message Count:
    what bell housing is needed? will the one from the a4ld work. dont really have the time or the funds for the t5 swap as of now
  4. dirtracer Founding Member
    Jun 14, 2001
    Message Count:
    944
    The A4LD bell housing will not work with a C4. You have to have a C4 bell specificly for a 2.3L. They are hard to find and costly but a good option if you don't need overdrive.
  5. 93lx2.3t New Member
    Sep 25, 2005
    Message Count:
    i talked to the guy i bought the car from he says the car has an AOD trans in it and it was just rebuilt
  6. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Hold On To That Car!!!!
    Don't get rid of it for anything!! You've got the ONLY 4cyl. AOD car ever produced!!
    Congratulations.
    :bang:
    At least it has been recently rebuilt.
  7. 93lx2.3t New Member
    Sep 25, 2005
    Message Count:
    im pretty sure its got the a4ld thou cause the bell houseing unbolts from the trans, arent they all one peice on the aod
Share This Page
