2.3T compression
Discussion in '2.3L (N/A & Turbo)' started by KenneBell, Apr 25, 2006.
  1. KenneBell New Member
    Apr 14, 2005
    Message Count:
    158
    What should good compression be for an 85 SVO mustang be. Did a compression check and got 148, 150,149, 151.
  2. stackz Founding Member
    Jun 14, 2001
    Message Count:
    1,322
    well, one rule of thumb is that all the #'s be within 10% of each other which those definitely are.
    why'd you do a compression check?? having problems still??
    I'm pretty sure I'm way off but I think I remember the #'s as supposed to be either in the 180's or right at 200 or so.
    but like I said, if you're not having problems and it's running 10% on all cylinders, you should be good.
  3. Asha'man Founding Member
    Feb 6, 2002
    Message Count:
    1,917
    140's-150's look good, and like Stackz said the consistency is really what matters.
    Brian
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Mine always read around 155 or so...gauges vary though. Your #'s look great.
  5. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    looks healthy...
  6. KenneBell New Member
    Apr 14, 2005
    Message Count:
    158
    Good, I'll keep the boost under 20 to avoid the joy of a headgasket replacement. Glad to hear compression is within specs.The car is running great, I just did a compression check to see where I was at. I beat a modified 2002 WRX!!! By the way my license plate on my 92 LX vert with the 2.3 turbo is: LIL4CYL
  7. myboyhasa66 New Member
    Jun 30, 2004
    Message Count:
    81
    yours is better then mine
Share This Page
