3.8 issues..help please!!!
Discussion in '94-04 V6 Mustang' started by SeriousSN95, Nov 26, 2006.
  1. SeriousSN95 New Member
    Jan 12, 2006
    Message Count:
    75
    hey gyys, im having some serious problems with my 95 stang.me and my dad have tried everything.The car just turns over and over for like 10 mins and starts. its runs great buit the first 5 times it will not start, we have swapped the tps out,maf out,crank pos.sensor,new plugs, gas filter, just about everybolt on peice. now it doesnt even want to start AT ALL.its got new plugs wires and coil pack. i dont understand it tho.it turns over and sounds like its back firing through the intake. even when we use starter fluid it wont start, just load up and pop really loud. please any help u guys can give me will defiantly be appreciated.thanks in advance Shawn.
  2. Skymarshal Member
    Nov 5, 2004
    Message Count:
    569
    You've verified that all the plugs are firing? Have you put a timing light on each wire to see if the plug triggers it?
    It's probably not a fuel problem, since it won't run on starter fluid either.
    As long as you have compression and spark, the engine should start. It almost sounds like your timing is way off. Since it's a distributorless ignition, you can't adjust it, but your ignition module might be bad. The service manual has a procedure to check it with a voltmeter.
  3. Silentst2000 New Member
    Sep 28, 2003
    Message Count:
    156
    No spark is either a bad EDIS module, coil, crank position sensor, or a fault in the wiring. You can test all of those easily with a volt meter.
Share This Page
