351W roller conversion
Discussion in 'Fox 5.0 Mustang Tech' started by latamud, May 10, 2004.
  1. latamud Founding Member
    Oct 22, 2002
    Message Count:
    779
    Ohio
    Hey everyone, I picked up an 89 351w non roller. I want to throw in a 5.0 roller cam.
    1. Can I mix a hydraulic roller cam with a mechanical roller lifter?
    2. I heard if I use the mechanical roller lifters with the connecting bars that I don't need to use the dogbones and spider and I could use the 5.0 HO cams, true?
    I know about the problem with the 5.0 roller rockers and cam not working with the 351 because the bore for the lifters is to short causing the lifters to lift up too far.
    Thanks
  2. SPEED FREAK Founding Member
    Aug 7, 2000
    Message Count:
    1,475
    Regina, SK.
    yeah a link bar setup will work or you could use a small base circle cam and do a bit of machining to the lifter bores to fit the dog bones. That way everything will work right and normal with no issues.
    Sponsored Ad
  3. mcw1020 New Member
    Dec 3, 2002
    Message Count:
    n.t. new york
    i have a 351w roller block if anybody wants to buy it 300.00 to take it thanks
Share This Page
