351w with decked heads ?
Discussion in 'Mustang II' started by strangeice69, Nov 15, 2003.
  1. strangeice69 New Member
    Nov 3, 2003
    Message Count:
    142
    the 351w i just bought has the heads decked, what will that change as far as performance. the guy did a complete rebuild. has "mild" cam, reman crank, mild cam, somethin about connecting rods
  2. Turbo II Founding Member
    Nov 20, 2000
    Message Count:
    1,538
    Depends on how much material was removed, the more that was taken the higher compression..a good thing in moderation (with today's pump gas)
    IIRC every thou removed "roughly" translates to one less cc in chamber volume? Or was it every 10 thou :scratch:
  3. parthos Founding Member
    Sep 22, 2000
    Message Count:
    532
    maybe the heads were "decked" so that the gasket surface was completly flat. Sometimes when you remove material from the head to gain compression, you end up with funky angles and intake manifolds don't match up anymore, then they have to be "decked" to get them to mate properly. Another consideration is pushrod length. Even though this should be checked with every engine build, it becomes more critical with machining such as this. What you want is the rocker arm centered over the valve at mid lift. Just some stuff to check.
  4. strangeice69 New Member
    Nov 3, 2003
    Message Count:
    142
    ok, its decked 10 thousands. will there be any noticeable gain
  5. strangeice69 New Member
    Nov 3, 2003
    Message Count:
    142
    the guy tore the motor down to build it up and put it in his 89 but plans fell through ...now its MINEEEEEE:)
  6. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
    I doubt it only a point or two
    now if you deck the block and threw in some flat tops you will then.
    but like was said before if you drop your heads down too much your intake manifold won't line up any more.
  7. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    Then it's better to machhine the intake as they are way cheaper and easier to replace than heads. {Edit} In case the machinest takes too much off or otherwise screws the pooch or if the heads are going to be used on another engine.
    BTW, heads are ''shaved' or 'milled', blocks are 'decked'.
  8. strangeice69 New Member
    Nov 3, 2003
    Message Count:
    142
    something was decked....the guy talks to fast and im not up on the technical talk
  9. parthos Founding Member
    Sep 22, 2000
    Message Count:
    532
    maybe the block was decked. They do this for two reasons, to make sure the piston is flush with the top of the bore, and it provides a flat surface for the gasket to seal to.
  10. strangeice69 New Member
    Nov 3, 2003
    Message Count:
    142
    i hate buying a motor that is partially built up. i never know where to go with it next.
  11. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    You also never know if what they say has been done has actually been done, and if it was done how well it was done.
    Ask Glenn.
    :rolleyes:
  12. Dano78 Founding Member
    Nov 1, 1999
    Message Count:
    2,662
    Normally every engine, block and heads gets decked/milled on a rebuild. BUT- this is only about a .003-.005 decking and/or milling on a normal basis to 'true' up a head or deck surface on the block. If you gotta cut .005 off, you had a pretty seriously tweaked head or deck.
    You're close Francis, .008-.010 will give you about 1/4 point in compression on the average. To get a full point you'll need to either cut the block deck .020 or mill the heads. For Mopars i think it's like .012-.014 to get 1/2 a point, which is what i'm toying with at the moment.
    Personally if you wanna raise the compression, get the piston with the largest compression height or a dome. If you need to do milling (cost effective) take it from the block. Whan you do that they can mill down the lifter valley rails (at either end where the intake mates) which will enable you to use any intake or head without it needing to be milled. And another thing, for no reason should you mill more than .020 unless you have no other choice or you're going for ubsurd compression. If that's the case, then your intake may have to be milled to correctly line up.
    I buy partially built engines all the time. Saves on $$$. You just need to take a little more time and check all the clearances. Hell, the last one I bought, the rods were in backwards (chamfer wrong way and piston notches 1/2 were backwards) Invest in plastigauge and a good ford smallblock rebuilding guide and you won't have a bit of trouble.
    As for your mild cam... that's a matter of opinion. Mild to one can be knarly to another. Get the actual specs if you need to. be sure to get the .050 duration numbers. Advertised Duration is a crock and is hardly accurate, especially when comparing other manufacturers' cams.
    Reman Crack- Most likely just a stock crank sent out and cut .010/.010 or .020/.020 to refinish the bearing surfaces. No frills. They can cut up to .040/.040 when thay turn a crank, but I wouldn't advise that at all.
    He probably 'Reconditioned' or 'resized' the connecting rods. This means the rod and cap mating surfaces were cut down and then bolted together and the hole where the crank would go is then re-machined to a 'true' circle again. And if applicable, you get new bushings on the smaller end if you have floatin pin pistons. Most all SB Fords are press fit pins unless you have some high-end race stuff.
  13. Dano78 Founding Member
    Nov 1, 1999
    Message Count:
    2,662
    I agree, so you must, check, and check again. Have the proper books and if you not sure, ask questions. Some things, like the boreing or hone job, you'll never know till you fire it up. But the rest of it is all pretty easily measureable. As long as a reputable machine shop did the work, I doubt there will be any problems. It's the fly-by-night garage based machineshops i worry about.. :rolleyes:
  14. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
  15. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
  16. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    it changes the rod angle against the crank. That way, the rod pushes harder (sorta) against the crank. more push = more power.
    This only works with an offset wristpin though. I know Im gonna get flamed on about this theory1, but I swear to ya that its true. I was in a Mopar 383 before and after, and I makes a REAL difference.
  17. 77sleeper GO BUCS!
    Oct 11, 1999
    Message Count:
    7,495
    that is OLD OLD OLD school I have seen in in a 289 back when vic was running edelbrock
  18. Turbo II Founding Member
    Nov 20, 2000
    Message Count:
    1,538
    :lol: Thanks! You guys are making feel better (I'm 38 going on 19 :D )
  19. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    sorry Turbs, but Im 24, so 38 is old for me :D of course, I remember thinkin 24 was ancient too. :rolleyes:
  20. Gunmetal5oh Founding Member
    Apr 11, 2002
    Message Count:
    1,095
    36
    Wart, you were made aware of what was done to the engine and what went into it, I sent you a list containing all the details.
    Furthermore, it's good to see that you still conduct yourself in a polite and friendly fashion.
    :lol:
Share This Page
