K kev1919 Founding Member Oct 15, 2000 795 0 0 MI Sep 25, 2005 #1 Sep 25, 2005 #1 will any other trans hook up to the 2.3 ? mine is slipping and leaking from the main seal.
bhuff30 Founding Member Dec 11, 2001 6,037 35 129 Olathe KS Sep 26, 2005 #2 Sep 26, 2005 #2 The C3 or T5 can be easily used behind the 2.3. Both require a longer driveshaft.
E egnorant Founding Member Jul 16, 2002 160 0 16 Deep East Texas Sep 26, 2005 #3 Sep 26, 2005 #3 Too easy! First thought is to recommend the T-5. However, once you have the tranny out it takes about 2 minutes to replace the seal. I have done an in and out seal change in about 1 1/2 hours. Bruce
J Jacob07 New Member Apr 5, 2005 96 0 0 Missouri Sep 26, 2005 #4 Sep 26, 2005 #4 The C3 or T5 can be easily used behind the 2.3. Both require a longer driveshaft. Click to expand... I'm under the impression the T5 does not require a different driveshaft. You will have to find and install the pedals if you go that route though.
6 67efivert Member Jan 26, 2003 348 0 16 lincolnton nc Sep 26, 2005 #5 Sep 26, 2005 #5 i have both in my back building and u do need a longer shaft for anything other than the a4ld
J Jacob07 New Member Apr 5, 2005 96 0 0 Missouri Sep 27, 2005 #6 Sep 27, 2005 #6 67efivert said: i have both in my back building and u do need a longer shaft for anything other than the a4ld Click to expand... Hmm...Thanks for the correction.
R RustBucket New Member Jun 8, 2003 585 0 0 Buford, GA Sep 27, 2005 #7 Sep 27, 2005 #7 Only the 5.0 guys can get away with keeping the same driveshaft when swapping from a slushbox to a manual tranny. Even the front yoke is different between the A4LD and the rest of the bunch.
