The kit includes:
1 Double T-Nut Latch Bracket with Gaskets
2 Single T-Nut Retaining Clip Brackets with Gaskets
2 Sunroof Latch Bolts with plastic and metal washers
Typically the factory parts corrode and then when you try to remove them the bolts break off in the brackets. Buy this kit and get your sunroof in tip-top shape.
This kit is only available at MCRParts!
http://www.mcrparts.com/shop/79-93-Ford-Mustang-Sunroof-Hardware-Kit-p-19909.html
