92-93 PCM???
Discussion in '94-95 5.0 Tuning' started by 5literstang, Sep 25, 2008.
  1. 5literstang New Member
    Apr 15, 2003
    Message Count:
    1,377
    will a pcm out of a late fox work in 94 gt? if so does it plug right in as long as its from a 5.0 5speed car? my stock pcm just come up prom error code everytime i scan it, my car has a dss 306 trick flow heads and intake, also a stage 2 cam, thanks guys, much is appricated to get it running right. :(
  2. Stanger007 Founding Member
    Sep 26, 2001
    Message Count:
    2,029
    No go on the plugin - I'd find a 94/95 PCM off eBay. You don't happen to have a chip on it eh? That'll throw a checksum error if not turned off.
    Wes
  3. 5literstang New Member
    Apr 15, 2003
    Message Count:
    1,377
    yeah but the 94-95 gt computers just suck in general, esp to a cam upgrade.
  4. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,262
    66
    They do not suck in general....just with the stock programming. It is a far better processor/computer compared to the fox A9 family. It is like comparing a 386 to a pentium3 or 4.
    Get a tune or tuner on the eec by either learning how it works or from someone who knows the eec (like wes the guy who posted above you) and you will be better off than with a A9 that will still need a tune to get the most out of your combo.
  5. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Those 94-95 pcm gotta suck :D
    I mean ..............
    You can find all kinds of stuff written about it all over the net :rolleyes:
    Those old wives tales will never die :rlaugh:
    If one could get a fox pcm to make great power with NO ISSUES what so ever
    and
    A set of 355's which will turn way less rpm on the highway than 373's
    as well as
    Get way more gas milage than 373's
    and
    Then make sure when they do up a stroker
    They do a 331 instead of a 347 so they don't have the oil issue thing
    as well as
    The 331 will not have a short life like you have with a 347
    Well ... If a fellow could wrap all that good stuff up in his 94-95 Stang :banana:
    He would be all set ... Now ... Wouldn't He ;)
    :rlaugh::rlaugh::rlaugh::rlaugh::rlaugh::rlaugh:
    Honestly 5literstang
    Sounds like you've been listening to
    or
    Hanging around peeps who TALK about it
    If you go and hang around some peeps who have DONE it
    You are gonna get a very different story :Word:
    The pcm in the 94-95 GT and Cobra can be made to operate just fine like
    Greg has said above :nice:
    btw ...........
    Greg knows his way around a 94-95 pcm
    and
    He would be one of those peeps I talked about who has ... DONE ... it :)
    Grady
  6. 5literstang New Member
    Apr 15, 2003
    Message Count:
    1,377
    i already have a tune, with a chip...my computer is doesnt allow me to scan, i just wanna know if a 92-93 pcm will work cuz i can get one for nothing, sorry about not posting about that before, my bad guys
  7. StangGT1995 have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,294
    88
    Have you tried reseating the chip? If it's not seated properly, or the contacts have corroded, you'll have issues galore. If you remove the chip, are you able to pull codes?
  8. 5literstang New Member
    Apr 15, 2003
    Message Count:
    1,377
    yes even with the chip out it still reads prom error code
  9. 2002BLGT Well-Known Member
    Dec 18, 2003
    Message Count:
    3,073
    56
    chip is probably still ok , sounds like the PCM took a crap , id find a used one on ebay , or call MPSautosalvage.com , they usually keep them in stock and will guarantee you get a good one
Share This Page
