94 gt starting issue
Discussion in '94-95 Tech' started by danieib, Oct 30, 2009.
  1. danieib New Member
    Oct 20, 2004
    Message Count:
    Shelbyville, KY
    A couple days ago the car would not start, no clicking or turning over at all. Hours later I tried again and was able to get it started and drove to advance auto were they tested the battery and alt. and all was good. Been started 10 times since then and has been fine. Driving tonight I noticed the battery light was flickering on/off. Shut car off and it did the same thing, would not do anything. Roll started the car and it runs fine.
    Do you guys think its just the starter? would the battery light have come on for that?
    Thanks
  2. Hef5.0weisen Active Member
    Mar 6, 2004
    Message Count:
    551
    28
    Clovis, NM...worst place I've ever lived
    just offering my .02 here,
    inspect the ground/negative cable from the battery, maybe a good cleaning for the terminal as well, make sure its good and tight. also, look at the ground wire coming off the ccrm, it only has a sheet metal screw attaching it to the body. inspect that as well, clean it up and replace the sheet metal screw with a bolt/nut. and look at the leads on the starter, and again clean em'up, good'n tight
    i read somewhere that most electrical problems are the result of bad grounds, maybe that'll be your case
    good luck :nice:
Share This Page
