97 Thermostat replacement
Discussion in '94-04 V6 Mustang' started by 97convert, Nov 5, 2007.
  1. 97convert New Member
    Nov 5, 2007
    Message Count:
    Concord CA
    Hi -
    Does anyone know how to replace the thermostat in the 97 V6 motor? I am relatively mechanically inclined and think it should be a basic fix but nit totally sure. Any help or resources are appreciated.
    Thanks
  2. doc4444 Founding Member
    Jul 11, 2002
    Message Count:
    235
    Sorry I can't tell you the steps, but if you get a Haynes or Chiltons manual that should show you how.
  3. redhot96stang Member
    Feb 4, 2011
    Message Count:
    31
    cuero,texas
    easy does it
    its really easy i have a 96 v6 and right in the center of the motor on top where the radiator hose connects is the thermostat housing its attached with two bolts using a 10mm socket loosen them up and then take of the hose you should see the thermostat but note put it back on the same way u took it off. When goin to get a new one make sure to get a fail safe thermostat with the o-ring and gasket. and some rtv silicone then bam its just plain out easy.
Share This Page
