99 Cobra performance
Discussion in 'SVT Forum' started by D-mann, Dec 31, 2003.
  1. D-mann New Member
    Dec 31, 2003
    Message Count:
    29
    I have read that the 99 Cobras had a recall because their engines were producing less than 300hp. Apparently they replaced the mufflers and intake manifolds of all the cobras. My question is what was their performance after that? I have seen a 1/4 mile time of 13.9 and 0-60 time of 5.4. Do those numbers refer to before or after the recall was done?
  2. RAYS99COBRA New Member
    Dec 12, 2002
    Message Count:
    38
    Post-fix, these are 13.5 second cars in stock form. 0-60 at 5.5 is very close. Wheelhop and gearing is our only enemy in stock form. These cars are now very affordable due to the bad press they received. If it's had "the fix", it's just as strong as the '01. If you are contemplating purchasing one, see if it's had "the fix" (most if not all have) and go for it.
  3. D-mann New Member
    Dec 31, 2003
    Message Count:
    29
    Cool, I'm glad to hear from somebody that owns one. I'am looking at 99 Cobras cause the 01's are definitely more expensive. I was a little worried because the 99's had lower performance numbers than the 01's and if that was still true after "the fix" then I wouldn't get a 99. I agree that almost all cobras got the fix cause it shouldn't be too hard to recall only 5000 cars or so.
  4. D-mann New Member
    Dec 31, 2003
    Message Count:
    29
    Whats the best, foolproof way to find out if they had the fix??
  5. missouri_guy197 New Member
    Sep 1, 2002
    Message Count:
    1,441
    I think you can call SVT at 1800-FORD-SVT and give them the VIN and they'll be able to tell you if it's had the fix done to it...
  6. lafear01 Founding Member
    Dec 4, 2001
    Message Count:
    452
    the average joe will NOT run a 99 Cobra to a 13.5x. Average Joe will run a 13.8x if he's lucky. 0-60 is about right. NOTE: the 01 cobra has many favorable upgrades as compared to the 99 cobra (if the opportunity comes your way):
    upgraded tranny T3650
    upgraded seats
    reinforced independent rear suspension (31 spline vs 28 spline on the 99)
    polished rims
    strengthened aluminum block
    Good luck with your decision,
    Chris
  7. CobraCruiser New Member
    Dec 9, 2002
    Message Count:
    248
    There is a sticker underneath the hood. It has the tech's name on it, if I remember correctly, along with a numeric code for what was done. Some techs put the sticker on the radiator support and others put it on the underside of the hood, for some reason. Mine was on the radiator support.
    A few things were involved. They replaced the intake manifold, replaced the exhaust after the cats, changed the tensioner pulley and, I believe, reflashed the computer.
    Get the '99. Replace the seats with good aftermarket seats. The regular seats are terrible, with no useful side bolstering or headrest. They are fairly comfortable for a long cruise, though. You can get good seats for a very reasonable price.
    :flag: :nice:
  8. MC Cobra Founding Member
    Dec 28, 2000
    Message Count:
    1,266
    Just my .02 but those trannies have not proven to be any better than the T45.
    The 31 splines break just as easy as the 28. It's not the spline count but the shaft itself.
    Strengthened block? Never heard that before.
  9. MC Cobra Founding Member
    Dec 28, 2000
    Message Count:
    1,266
    Okay, here's what they did to my car and to every other one they fixed.
    Replace the mufflers, replaced the intakes with either an extrude-honed intake or acid dipped intake(increased flow) and re-flashed the computer. That's it.
    On my car they put a sticker on the front edge under the hood and the intake has a blue dot.
    They also used a green dot and also a green & blue dot.
    Do a search on this topic, there's quite a few threads about this here and also the corral.net
  10. missouri_guy197 New Member
    Sep 1, 2002
    Message Count:
    1,441
    I agree on the block, as far as I know, all aluminum 4.6L blocks were the same...
  11. RedCobraVert Founding Member
    Jul 7, 2001
    Message Count:
    196
    strenghtend BLOCK????
    WTF? I am calling :bs:
  12. Nazman New Member
    Apr 28, 2000
    Message Count:
    1,097
    Not this again.
    This have been posted like a billion times.....may be more :bang:
    A quick search will answer all your questions.
    The 99 vs. 01 debate....please not again.
    Naz
  13. D-mann New Member
    Dec 31, 2003
    Message Count:
    29
    Sorry to bring up some bad memories guys. I'm new to the site and didn't notice the search feature.
  14. Nazman New Member
    Apr 28, 2000
    Message Count:
    1,097
    De-Mann,
    Sorry for my "smart a$$" response and not being informative at all. You had an honest question by the way.
    I just hate to see everytime that a 99 Cobra question comes up that the 99 vs. 01 debate always shows up.
    The 99 Cobra's are great machines, so are the 01 Cobra's and all alike.
    The 99 had thier "bad rap" due to the "low HP" but was fixed. Here in Stangnet there at least 50% of all 99 Cobra's that use this forum have been developed and making over 300 RWHP (345HP at the motor) easily.
    If the 01 has better seats, that is a matter of taste. If they have 31 spline, that did not fixed anything over the 99s since that was not the problem and even today the 03s still break theirs being much stronger.
    The 01s had their problems with the "Ping", "Wicked (on th bad side)" power curves (too many dips), and on and on and on.
    What I'm triying to say here purchase (if you have not as of today) what better fits your taste, and pocket.
    I had my Cobra since it had .7 miles in the odometer and I have loved every single of the 36XXX miles that I put on after.
    The car has giving me NO PROBLEMS what so ever (other than a broken transmision my own fault of not having an aftermarket shifter and power shifting at o/a 14K and a broken passenger side half-shaft due to again, Drag Radials, good track and a healty 4500RPM launch. Other than that, the car made 264RWHP (303HP) before the fix, 291 (334HP) after the fix and now a few mods later :D 333RWHPs (383HP)! (all using about the 15% standard)
    So, don't let people tell you that the 99s are weak, suck, had bad seats or what ever they want to say. For me, 99 are as good as the 01s and viseversa.
    If you want to find out about the fix on a 99 Cobra, call 1800fordsvt and you will be good to go. Just provide them with the VIN number of the car of interest.
    If you have more questions, please don't hesitate and ask or email me personally at stang32v@yahoo.com
    Welcome to STANGNET!
    Naz
  15. Wes G Founding Member
    Nov 21, 2001
    Message Count:
    126
    I would have to concur with Naz.
    Not all of the Cobras sold in 99 were down on power. Some were worse than others, and therefore benefitted greatly from "the fix" while others only noticed 3-5 horsepower from the exhaust swap. My car was an example of the latter, as it was making an estimated 318 hp at the flywheel the first time I took it to the dyno. After the fix my car dynoed at an estimated 331, but I had also changed to the K&N filter and yanked the silencer. Also, just so you don't get concerned about the tranny or halfshafts, I ran the stock halfshafts for about 6 months after I installed the SHM 5.2, and the stock tranny for about another year without any breakages. In my experience, the car was a great purchase. Besides that, I don't think I could be pissed off at Ford for anything because I have literally beat the crap out of this car since the day I bought it and haven't found anything wrong with it.
  16. terrydf New Member
    Dec 30, 2003
    Message Count:
    72
    My 99 dyno'd 264 RWH after the fix :rolleyes: Its gone now...
  17. 99CobraJMS Founding Member
    Sep 10, 2001
    Message Count:
    1,572
    The min DYNO range should be RWHP 269-272 after the fix. Not my probem anymore, just 60 ft times. :D :D
    John
  18. D-mann New Member
    Dec 31, 2003
    Message Count:
    29
    Thanks for the info Naz, and its great to be on the site. I have decided to go with a 99. Its the best option for me as far as money.
  19. 99SVTAddict New Member
    May 8, 2003
    Message Count:
    643
    The 99 Cobra's are OK I guess :nice: :D
Share This Page
