Here is a little info on the 99 Cobra
cast aluminum block and heads
iron cylinder liners
compression ratio 9.85:1
horsepower 316 @ 6,000 rpm 320 after fix (mine is 363 minor upgrades)
torque 316 lb/ft @ 4,750 rpm
double overhead camshafts
four valves per cylinder
final stock gear 3.27
all-speed traction control
13.0 in front Brembo disc brakes
11.65 in rear vented discs
ABS brakes
independent rear suspension
tilt steering, remote mirrors, power windows, power locks, power trunk lid,
6-way power driver seat, rear window defrost, air cond, speed control,
Mach 460 AM/FM cass & CD player, remote keyless entry
top speed 150 MPH
Quarter Mile 13.8 @102 mph
*The above info was original factory info.
There was a recall by Ford because the 99 Cobra did not meet advertised horsepower. Most of the cars have had this "fix" done by Ford and you can find out by getting ahold of Ford. They replaced the lower intake manifold, replaced the muffler assemblies, and reflashed the powertrain control module. After the fix the car has performed as good or better than advertised.
I have a 99 Cobra with 30,000 miles and highly recommend it.
Scotty
