A/C Problem...need quick help!!
mightypoof
523
Glendale, AZ
I just finished putting A/C on my car. The problem is the clutch on the compressor will catch only for a couple seconds at a time. It turns on and off. Why would it do this? I need help quick because I am moving to Arizona on Sunday...THanks...
-TG
ssjmaverick23 said:
that sounds to me like u need to charge it up some more since it is cycling like that hope that helps
exactly
1) your Pressure Safety switch is bad
2) You dont have enough refrigerant in the system to make it stay on. If you just installed it i have to assume you are using R134A and NOT r12. I would pick up a leak tester, or a check gauge and see how much pressure is in the system. Also did you use a used Dryer (black canister) They should be Replaced each time the system is opened. You lose alot of efficency if the dryer is old or "full"
Dr.
