A pillar Gauges
Discussion in 'SVT Forum' started by Morpheusgpr, Mar 25, 2004.
  1. Morpheusgpr Founding Member
    Jan 29, 2002
    Message Count:
    257
    How hard to install these? I am thinking about a dual maybe a trio with fuel pressure, tranny temp and maybe nitrous pressure for when I get around to installing nitrous which could be switched out later for a super charger.
  2. 99SVTAddict New Member
    May 8, 2003
    Message Count:
    643
    The pod itself is easy...but the fuel pressure can take some time.
    Not sure about the other two...I have fuel and boost from autometer. :nice:
  3. CinciCobra New Member
    Jun 14, 2002
    Message Count:
    27
    Exactly, the braided line for the fuel pressure will be a b#tch to get routed under the stock trim!!! I have my fuel pressure in a guage bezel dual mount along w/ my boost, and have my A/F ratio along w/ my oil pressure on my dual pod. The autometer bezel isn't the highest quality though - so maybe you could consider mounting your fuel pressure on your cowl outside old school style. Not great for a daily driver, but looks sweet for a weekend cruiser!!!
  4. Morpheusgpr Founding Member
    Jan 29, 2002
    Message Count:
    257
    I was under the inperssion running braided line was unsafe? I thought the gauges were using electrical senders removing the need for a braided line?
  5. 9COBRA7 Founding Member
    Jul 16, 2002
    Message Count:
    131
    I've always heard if you have any type of fuel goin through a line the gauge must be outside the car, thats kinda dangerous to put it inside.
  6. 99SVTAddict New Member
    May 8, 2003
    Message Count:
    643
    Correct. I have the electrical guage. The only thing I don't really like about my fuel guage (and this is true on any 99+ returnless fuel system) is that the needle bounces around. So when I'm at idle for example, the needle bounces between 31 and 34 psi....I know it's at 32 but it jumps a little.
  7. iskybantilus New Member
    Jan 20, 2004
    Message Count:
    Well, the electric should be used anytime inside a car for fuel pressure. its less accurate, but much safer. a fixed mount mechanical gauge can be mounted under the hood for tuning, and referencing against ur elec unit, but i would only mount elec inside. just my 2 cents
  8. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    The same with the nitrous. I think they have finally came out with a electrical vs mechanical gauge. I would not want the nitrous to spring a leak while inside the car!
Share This Page
