Adding Timing
Discussion in '94-95 5.0 Tuning' started by Guero, May 21, 2007.
  1. Guero New Member
    Oct 12, 2005
    Message Count:
    2,195
    You add timing for WOT at load .70 and up right at your desired rpm???
  2. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Ive always added/subracted from the top row for my WOT tuning.
    I Adjusted the row below it to very close to the same thing, and adjusted all other rows acoordingly for my supercharged set-up.
  3. Guero New Member
    Oct 12, 2005
    Message Count:
    2,195
    So just the top one?? which is like .90
  4. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Upon datalogging at WOT your above that .90 anyways, so thats what Ive always done.
  5. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Yes the top row is just dandy for WOT tuning :)
    I challenge anyone to do several 15 to 30 second datalogs with these driving
    conditions :D
    Find a level place where you can gently take off in first gear.
    The idea here is to just get the car rolling to about 5 to 10 mph.
    Gently shift to second and accelerate to say 3k to 4K using only 5% throttle
    for the entire time of acceleration.
    Do another just like that with 10% more throttle
    Another with 10% more
    and so on
    Be sure you duplicate each run exactly except for throttle position
    and
    Be sure you datalog load
    You are gonna find ............
    It don't take much to hit the top row of the fuel & spark tables :eek:
    and
    You don't even need WOT to do it ;)
    Load is critical on our cars :Word:
    so
    Its critical a self tuner relates to how much of it he creates under
    all different driving conditions :)
    Grady
  6. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,262
    66
    Yep, the load is kinda easy to get high enough to put you at a WOT condition.
    Also noticed that the J4J1 base table top row is like .79 or something. From what others have stated they go "WOT" at is like 2.8-3.2v or so on the maf depending on the combo. That is one thing I was looking at on my log the point it went "WOT" or in the high load area.
    It also shows how important a wideband is...its that easy to be out of the "easier" to tune part of the tune and you cannot just tune ONLY with the KAMFR.
  7. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    I did so much CL datalogging :crazy: when I was just starting to
    understand :scratch: how the slopes, offsets, kamrf, lambse
    and the like all react to each other.
    As you know Greg, you can't use much throttle or you slip out of CL.
    I worked with a self ported E7 head based combo and my current sig
    combo and found it interesting that 2.6 maf volts was the highest I
    ever saw while staying in CL on both of those combos :)
    There is a long gentle rise on the highway and I could use it
    to generate my greatest amount of pulse width while still staying in
    CL. No matter what I did as far as throttle or speed, I found I could
    start the climb up that little hill in 4th at 50 mph with the throttle just
    cracked open and at around 70 to 75 mph ... I slipped out of CL and
    the throttle was at a maximum of about 1/4 to 1/3 of the way past
    closed position.
    Hard data ... sometimes you learn so much from it :nice:
    and
    Sometimes ... you're like :scratch:
    I know the answer is in there ... some where ... but where :rlaugh:
    Grady
Share This Page
