Aftermarket C-Clips?!
Discussion in 'Fox 5.0 Mustang Tech' started by bobbys9350, Apr 11, 2005.
  1. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    does anyone make aftermarket c clips i should get? i just got all my parts for my rear end including Moser 31 spline axles. I am wondering if anyone even makes aftermaet clips? also i need studs, should i get some kind of aftermarket stud? or just get stock replacement? if i get aftermarket which kind should i get? they need to fit under the center caps of pony rims, also do these require different lug nuts? any help would be GREATLY appreciated, thanks guys! :cheers:
  2. bluevenom867 I will have images of molesting stuffed animals in
    Dec 16, 2003
    Message Count:
    1,757
    St.Petersburg,FL
    Not that I know of,you can get C-Clip eliminators which are safer anyway.
    Do the axles have studs on them?You should be able to just cut off what up dont need,other wise ARP makes studs.Or you can use grade 8 bolts.
    Not sure what size the stock studs are,but the studs on my Moser axles are 1/2".
    Sponsored Ad
  3. Stang8URMPRT Banned
    Dec 28, 2003
    Message Count:
    1,120
    Daytona Beach, FL
    How would you use BOLTS are wheel studs? lol... Anyway... Aftermarket c clips? Yeah, I've seen some made of titanium that weigh 1/2 an ounce lighter and improve 1/4 mile times by over 1 second. :rolleyes: :p
  4. bluevenom867 I will have images of molesting stuffed animals in
    Dec 16, 2003
    Message Count:
    1,757
    St.Petersburg,FL
    Wheels studs are bolts.
    The bolt heads are behind the axle head.
  5. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    im wondering if thye make better c clips for safety lol
  6. bluevenom867 I will have images of molesting stuffed animals in
    Dec 16, 2003
    Message Count:
    1,757
    St.Petersburg,FL
    The problem with c-clips is not that there strong enouf,its that they fall out.
    So weld em' up;I'd like to see you get your axles out of the rear end then,hun :rlaugh: ?
  7. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
  8. Stang8URMPRT Banned
    Dec 28, 2003
    Message Count:
    1,120
    Daytona Beach, FL
    Never seen wheel studs that "bolt" onto the axle flange. They are usually splined and are press fit.
  9. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    what kind should i get?
  10. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    what kinda studs should i get guys?
  11. TT91 New Member
    May 23, 2003
    Message Count:
    1,610
    Paramus, NJ
  12. bluevenom867 I will have images of molesting stuffed animals in
    Dec 16, 2003
    Message Count:
    1,757
    St.Petersburg,FL
    Better look at a Moser axle that comes with studs.I just got my 5lug Moser axles and that is what they come with,bolts.
  13. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    does arp make stock lenght sutds? does anyone have a link from summit, PLEASE!?!?! THANKS! :)
  14. TT91 New Member
    May 23, 2003
    Message Count:
    1,610
    Paramus, NJ
    www.summitracing.com
    [IMG]
  15. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
  16. TT91 New Member
    May 23, 2003
    Message Count:
    1,610
    Paramus, NJ
    search ARP studs in summit. Maybe throw a "wheel" or "axle" word in there.
  17. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    lol, ok ok, ill find it :D
  18. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    ok, i have no clue what size i need to fit on stock pony rims??????
  19. 89MustangGX I have nothing productive to add!
    Jul 3, 2001
    Message Count:
    10,342
    Mill Creek, WA
    Mine from Strange are screw-in. There are two types, press-in or screw-in. It's not unusual.
    I had my studs packaged with my axles -- I think I might call Moser and have them send you some. Otherwise, if it helps, stock studs are 1/2-20, and long studs are 3", stock length is 1 1/2" or so IIRC.
  20. bobbys9350 New Member
    Mar 31, 2005
    Message Count:
    473
    if i get 3" will they clear the pony rim center caps? and will i need new lug nuts? thanks!
Share This Page
