Aftermarket Cylinder Heads?
Discussion in 'Classic Mustangs' started by Vinyl66, Apr 6, 2004.
  1. Vinyl66 New Member
    Mar 21, 2004
    Message Count:
    399
    I was just browsing through the Mustangs Unlimited catalog when I noticed that some cylinder heads are specific to certain years of 302's. The TFS heads for example state years 82-95. Edelbrock has performer heads and Performer 5.0 heads. What is the difference. Would these heads not work on my 302 (from a 1971 Mustang)?
    I know I have seen several early mustangs with new aluminum heads on them. Certainly the old 289's and 302's can use the high flowing heads like the new 5.0's can. Just wondering why the specific 302 years in the catalog.
  2. Max Power New Member
    Jul 31, 2003
    Message Count:
    1,776
    Mostly emissions compliance. The performer 5.0 is meant for newer cars and the performer for older non-emissions cars. They flow about the same. I think heat crossovers may be the major difference.
  3. hobbyhorse New Member
    Sep 14, 2003
    Message Count:
    26
    Could also be listed that way because of the pedestal style rocker arms on the late model stuff.
  4. coolblue65 Founding Member
    Jul 26, 1999
    Message Count:
    1,211
    36
    Max Power & Vinyl66 are both right, but they do make heads for early models as well. Although my Trick Flows required me to do some minor (and easy) modifications to the block to work because its pre-69.
  5. allcarfan The Answer Man
    Apr 8, 2001
    Message Count:
    3,754
    Arent the water passages a little different too?
  6. fitzm65 New Member
    Jan 6, 2003
    Message Count:
    197
    You are going to want the heads that do not have all that crappy emissions and smog stuff on them. Not that I am saying buy them from anywhere, but if you look in jegs or summit they have the differences more mapped out for you. You can also log onto their websites and check out different heads for different applications.
  7. goe New Member
    Jun 23, 2003
    Message Count:
    64
    I bolted AFR 185s w/all smog provisions on my 67 block. No problems. I think the main issue is with pistons....?
Share This Page
