alignment ?
Discussion in 'SVT Forum' started by ONEBADPNY, Nov 26, 2007.
  1. ONEBADPNY New Member
    Nov 10, 2002
    Message Count:
    203
    Is there anything I need to get in order to get a good alignment on my 99 cobra since i lowered it. will the alignment shop be able to get it with in specs with out buying something else?
  2. thomas91169 I'd donkey punch my sister.
    Aug 19, 2005
    Message Count:
    493
    what did you lower it with and how low?
    i think 1-1.5" you should be fine, anything lower requires CC Plates
  3. ONEBADPNY New Member
    Nov 10, 2002
    Message Count:
    203
    i used H&R sport springs.
  4. ONEBADPNY New Member
    Nov 10, 2002
    Message Count:
    203
    the alignment was as close to specs as he could get it. but its not within factory specs. said my tires both front and back may wear on the insides. anything i can do for this besides just caster plates?
  5. ONEBADPNY New Member
    Nov 10, 2002
    Message Count:
    203
    i don't know what to do. i think i am going to get some poly isolators and throw them in the rear. the rear is a little lower then i like so i hope these will bring it up a little bit anyway. going to get some caster plates for the front but what do i do about the rear? i can still tell by looking at it that the camber is set in to far. here is a link to the pictures i have right now. http://www.corral.net/photopost/showgallery.php?cat=500&ppuser=33800
Share This Page
