Alt, Starter, and things
Discussion in '2.3L (N/A & Turbo)' started by kiddiccarus, Jul 15, 2004.
  1. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    I am getting ready to buy parts to put on the Jack Stand Queen. What year parts can I buy to put on there. Treat me dumb. I have the 86 Merkur PS pump, and Alt. I think thay are v-belt and I would like to go to Serp like my 93. Will the 93 parts work?
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    The serpentine accessories will work, but you have to swap on the correct brackets too. I'm doing the same thing whenever I finally get my new engine into my thunderbird, it was an '84 engine so I'm gonna take the brackets off my thunderbird's old engine, clean em up, paint em, and put them on the new engine.
  3. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Not sure if the 91-up brackets were different. I used everything from the N/A on mine.
  4. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    Hmmm. Did any 2.3T come serpentine? That is s dumb question because we would have it if they did. Why wouldnt they match it is still a Lima isnt it?
    What year are you pulling the serp items off Red?
  5. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    87-88 Tc are serpentine
  6. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    SURE give a list of things to buy now, Man pullies and parts lol, No seriously what do I need in a list to do a serp conversion?
  7. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    If you're keeping the A/C everything on that bracket will stay the same. Just find stock crank and water pump pulleys. Ford used one very common P/S pump so all you really need to do is change the pulley there to and same with the alt. That leaves the bracket and tensioner. Simple junk yard parts.
    You just need the pulleys. I don't remember getting anything else.
  8. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    I need to make a list and head to the J/Y. I am going to buy some parts on TF first to try and get a T5 into the car in the meantime.
  9. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    What is the advantage of the serp conversion? Better availability of parts?
  10. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    supposed to be less drag....I thought, but its more belt surface touching so that doesn't make alot of sense.
    "Cause a V-belt 'll never turn 'at supercharger without slippin'":D
  11. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    LOL, Well at the point my engine is right now I can go either way so I will start looking at peoples extra parts, Hint Hint.
  12. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
  13. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
  14. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    Man I have to find a 93 bracket and try to mount it now or buy all 87-88 tc parts
  15. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    Not sure if getting TC stuff is the best way either. The turbocoupe's powersteering system has a seperate resevoir. Not a problem just mount it on the fenderwell. "Randy" from TF (Evil140 here) ran into the 7's with that style.
  16. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    87-88 TC
    Alt or just pulley
    Starter
    Crank Pulley
    water pump pulleys
    P/S pump pulley
    Seems simple enough If you run across a complete set of pulleys let me know and we will make a deal.
  17. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    looks right.
    As far as the A/C goes I'm referring to using everything currently on your 93.
  18. kiddiccarus New Member
    Dec 24, 2003
    Message Count:
    1,298
    Sounds good I wont need the AC stuff on the rail buggy anyways. That is what the 2.3 N/A is going to go on.
  19. BlackPony2000 New Member
    Jul 2, 2004
    Message Count:
    95
  20. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    :nice:
Share This Page
