Roush Anyone have this problem?
Cali 281SC
95
My car starts perfect every morning and when it's been sitting for a while (several hours or more).
However, if I have been driving it, shut it off, run in the store or house and run back out, it will turn over several times and sometime won't start at all unless I tap the gas (which obviously shouldn't be necessary because of the injectors).
I have an 02 S/C with 7k miles.
I don't know if it's a heat sensor, fuel pump what....
Anyone know what's goin on? :shrug: :shrug: :shrug:
Thanks for the help.
this is a problem
this is a problem soon enough you will be driving don the road and your car will die and you will get out at the bank and your car wont start i had all this happen to me and it ended up being the key reader in the steering wheel it had to be replaced the part is only like 50 bucks but it ends up cost like 300 because of the labor
Common problem for sure.
The only way to fix that is to give it just a hair more fuel at warm start in the tune. When it's warm if you can get it to start with your foot all the way in it every time with one good 2-3 second crank then that's your problem.
As you can see here most guys live with it. I myself couldn't stand it with my 01 and my 02 so I dialed it out.
Agreed!
This is something a tune will fix. My car had it as well, gave it back to the tuner, and they added just a touch more fuel. During cold start it was the worst, which is opposite in your case, but the problem is the same.
