ATF added to the engine
Discussion in 'SN95 4.6 Talk' started by clipperfan65, Apr 26, 2009.
  1. clipperfan65 New Member
    Apr 26, 2009
    Message Count:
    My helpful son topped off my '98 mustang GT with a quart of synthetic ATF...the other 4 quarts is normal 10W-40 oil - - do I need to run to the station and get it changes or can I wait until I change it on schedule - about 2,000 miles from now?
  2. Chucks98 New Member
    May 4, 2008
    Message Count:
    15
    lol my mom did that to her old plymouth breeze. personally i'd change it. atf is thinner than motor oil and probably not designed to take the heat and abuse oil does
  3. DBMSTNG I fantasize about it being BIG!
    Apr 24, 2002
    Message Count:
    3,952
    56
    change it out ASAP.
  4. AdRock Member
    Nov 14, 2003
    Message Count:
    522
    ATF has been used as an engine cleaner, just like the Motor Flush you can buy at an auto parts store. Chances are that it has worked any gunk in the engine loose. It's not a horrible emergency but I wouldn't drive it too far.
    Put some fresh oil and a new filter on. Just use some cheapo oil & filter. Then change the oil & filter again after a few days and use the stuff you normally use. That'll get any residual out and it'll be fine.
  5. crazystang25 Member
    Jan 26, 2009
    Message Count:
    498
    ya u will have a cleaner engine but don't leave it in.
    Posted via Mobile Device
  6. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    ATF makes a horrible engine oil. it is a commonly held myth that it contains more detergents then motor oil. at one time it may have been true, but with SM oils, it couldn't be more from the truth.
  7. crazystang25 Member
    Jan 26, 2009
    Message Count:
    498
    Didn't say it made a good lubricant. Said it cleans it pretty good.
Share This Page
