BBk Equal Length Headers Don't Fit
Discussion in '94-95 Tech' started by MoNkEyMaN912, May 27, 2009.
  1. MoNkEyMaN912 New Member
    May 27, 2009
    Message Count:
    9
    Fort Drum NY
    I've had the Chrome finish which was a bad idea but they did fit just rusted after like 4 yrs so I decided to get the same ones since they fit except I went the ceramic coat but for whatever reason these don't fit. I've dented the heck out of hit trying to get it to clear the steering shaft no luck so I bought the flaming River steering shaft that is supposed to give better header clearance no luck there either I'm using Mr.Gasket copper gaskets. Can header gaskets really make that much of a difference? Jegs and summit both said that they should fit with stock motor ive got Edelbrock performer heads but the old ones fit why won't these fit? Anybody else have these problems?
  2. 1995GTStang New Member
    Feb 10, 2009
    Message Count:
    74
    Washington State
    I just ordered a set of BBK shorties #1525. I was told it was just the equal length ones will not work because of the tubes extend too far out and cause issues.
    I do not know much about the equal length headers, did you compare the two to see if there is any difference in they were they made??
  3. MotiV8ed_95GT New Member
    Dec 3, 1998
    Message Count:
    57
    Parkville
    Check your motor mounts, if they are sagging at all that will give you issues with your steering shaft clearance.
    Ross
  4. JJ95GTID Active Member
    Sep 22, 2003
    Message Count:
    1,057
    48
    Phoenix, AZ
    I have the BBK E/L ceramic coated headers. No fitment problems here.
    Maybe the ones you got were for Fox Mustangs :shrug:
    I would check the part number and make sure it is for the 94-95 years.
  5. ProKiller Founding Member
    Apr 26, 2002
    Message Count:
    2,941
    58
    PA
    i agree with both Ross and Joe. start by checking the to make sure you got the right headers. then replace your motor mounts, if they are stock they could probably use it anyway.
  6. MoNkEyMaN912 New Member
    May 27, 2009
    Message Count:
    9
    Fort Drum NY
    1995GTStang Yeah i Checked the difference didn't look like anything was different about them I have heard that it could be the motor mounts i'm gonna get another set on order and this time save the reciept incase this happens again because i've jacked this set up trying to make it fit. Motor mounts could use a new set which would anybody recomend? OEM or the stiffer ones?
  7. earleys94gt Member
    Aug 31, 2003
    Message Count:
    829
    Ashley, Ohio
    You could just get OEM motor mounts, but I would get some poly urethene mounts. Might as well up grade while you are replacing them.
    On the subject of the equal length headers, they only issue I had when I installed mine was the dip stick. After a slight "modification" to the stick, they fit just fine.
  8. BlackVert Mustang Master
    Oct 3, 2003
    Message Count:
    5,595
    78
    Bethesda, MD
    i hated my BBK EL headers. all they did was burn spark plug wires and make it really difficult to get to the plugs. imo, they were not even close to worth it
  9. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    Burlington, NJ
    yea... i vote to sell them and get long tubes....
  10. MoNkEyMaN912 New Member
    May 27, 2009
    Message Count:
    9
    Fort Drum NY
    it's gotta be my motor mounts or the wrong headers but i called jegs and BBK and they both said the part number was right icompared the looks from my olds ones (that fit) to the new ones they looked the same but not a fit. So go with poly urethene mounts are they a pain in the but to install? i've put them in on some cars and swore that i would never put another set in .............lol
  11. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    If you are gonna get another set of shortys .........
    I'd do the regular shorty header over the equal length
    There is not gonna be much difference ... if any ... between them
    I don't know what the long term plans for your Stang are :shrug:
    but
    LT's can yield a noticable gain over shortys down low and at mid range ;)
    Might think a bit long term before you part with the cash :)
    Grady
  12. MoNkEyMaN912 New Member
    May 27, 2009
    Message Count:
    9
    Fort Drum NY
    Grady What type of headers are you running? I would like to go with long tube right now can't do it because i will have to change out all of my pipes but for future what's your opinion one the best brand?
  13. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I run Mac LT's and one of their catted H mid pipes
    You see a lot of peeps run Mac and BBK LT's
    I'd bet there is not much if any difference between em when talking
    performance
    Some like the fact BBK uses a solid flange :shrug:
    I went with Mac simply because when I put my sig combo together
    BBK did not offer an egr bung at that time
    Yes ... when one moves away from shorty to LT's they do have to
    commit to a different mid pipe :(
    however
    Depending upon application............
    LT's can offer substantial benefits that you just can't get with shortys ;)
    Grady
  14. MoNkEyMaN912 New Member
    May 27, 2009
    Message Count:
    9
    Fort Drum NY
    Grady Thanks for your healp instead of goin with shortys i may just wait and go with lt and get a different mid pipe did you have any fitment issues?
  15. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    None what so ever :)
    I would point out my application is with a stick trans (t-5)
    I do wanna say :D
    If you're planning on just a bolt on or two ......
    shortys would not be all that much of a compromise
    but
    If staying NA and doing h/c/i ... Yes ... LT's would be the way to go :spot:
    Grady
Share This Page
