Bigger gears
Discussion in '94-04 V6 Mustang' started by blackstang04, Aug 16, 2005.
  1. blackstang04 New Member
    Apr 26, 2004
    Message Count:
    11
    If i were to get bigger gears for my v6 what size should they be and what are the gear ratios? If anyone knows this u'd be a huge help thanks alot :bang:
  2. Give Me TP New Member
    Jun 17, 2004
    Message Count:
    984
    Republic of Texas
    Manual or Automatic?
    Stock ring gear is 7.5", I recommend going to 4.10s if you are changing them. You will also need a T-Lok or other limited slip differential. Since you have a relatively new 04 model I would go with new parts.
  3. OxMox turkeysammichesonhisface
    Mar 31, 2005
    Message Count:
    611
    Palm Harbor, FL
    4.10's are cool, I have them and love them. It really depends on what you are going to be useing your car for. Everyday driving with some slight modds and the occasional blast down the strip, then go with 3.73. Everyday driving with mild to heavy modds and/or a poweradder going to the track once every two weeks, then go with 4.10.
  4. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Buffalo, NY
    4.10's on a mildly to heavy modded car would get you into trouble as the ratio is so steep you would break the tires loose everytime. 3.73's are good for a lightly modded car/ YOu might even want to consider 3.55's instead which would be about the middle of the road.
    On my 98 manumatic, the 4.10's constantly cause the rear tires to break loose from 1-2 gear, and sometimes 2-3 gear, and that's with only ram air, axhaust, and shift kit.
  5. Mustang_02 New Member
    Jan 27, 2004
    Message Count:
    109
    410s on a power added V6 is a terrible idea. 373s in that case. I have 4.10s for a daily driver, highway and city. I love them. It makes the car get up and go. I also have an 8.8 rear end though.
Share This Page
