Body filler
Discussion in '2.3L (N/A & Turbo)' started by GT40 2, Apr 26, 2008.
  1. GT40 2 Member
    Oct 14, 2004
    Message Count:
    105
    What kind of body filler do you use? Im trying to find a better filler than bondo. I think NAPA sells something good.
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    I've used bondo...some people use fiberglass.
  3. satanas New Member
    Dec 16, 2005
    Message Count:
    200
    well depends what you needed for if you want to fill big holes you need what they call kitty hair or bondo with fiberglass strands,next down will be fiberglass jelly, has bondo with small tiny fiberglass material. then you use bondo the one that has nothing inside.I like to use the bondo with jelly resin it strong the bad thing is it gets hard but before it dries you can shape it with a tool that looks like a cheese grader. I used the bondo,(the pink stuff they sell at wall mart or auto parts, i used it as a last filler before putty to fill larger sand paper scratches its easier to sand. Their all from Bondo Brands.Well hope this helps.
  4. chromedog New Member
    Jan 14, 2006
    Message Count:
    555
    i like rage, and rage gold... (the gold has a small ammount of zinc in it) the both sand really easily, if you catch them before the fully harden, and neither of them pinhole to much. the biggest thing to remember about any filler, is not to apply over 1/4 inch thick, and to have a properly prepaired surface so the filler has a good "tooth" to adhere to...
  5. Mustang78 New Member
    Feb 8, 2006
    Message Count:
    494
    1/4"?!? i wouldent go over 1/8" thick, and if you have to keep it to a minimum..rage is very good along with topcoat lightweight body filler, the only bondo brand i buy is their professional(gold?) stuff and it doesn't compare to topcoat or rage..if you only need a quart or two why not spend the extra 5 bucks and be happier? bondo doesn't like to stick to paint either
  6. satanas New Member
    Dec 16, 2005
    Message Count:
    200
    You have to apply bondo to bare metal...I've use that stuff for years and haven't had a problem..
  7. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    +3 on the Evercoat rage Gold.
    Good stuff!
Share This Page
