body in white advice
Discussion in '2005 - 2009 Specific Tech' started by doc stang, Oct 21, 2008.
  1. doc stang New Member
    Mar 10, 2007
    Message Count:
    60
    if one were to build up a body in white for American Iron, (or Camaro-Mustang-Challenge, (if rules loosened)). . .
    does anyone know of a step-by-step guide as to how,
    i.e. in which order to do what,
    while using a wrecked donor for some parts
    and aftermarket for others.
    doc
  2. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    I always wanted to pick up a body in white. I think it would be a great way to learn about how a car goes together.
    As far as order, I don't think there's really any particular order for assembling.
  3. o0Dan0o Founding Member
    Feb 8, 2001
    Message Count:
    485
    I dunno about a guide, but basically something like this.
    Suspension(including wheels tires and steering to get it rolling), then roll cage installed (probably including seat install and any metal work on the car you don't want to do yourself), I'd do paint next, then drive train install (including all wiring, gauges and switches), last the odds and ends (fire suppression unit install, padding over the roll cage bars, ext.). This is typically the order I have seen, the engine almost always goes in last.
    Dan
  4. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    Unless it's a complete drop-in, the only change I would make would be to fit the engine and headers before painting. Then pull them and paint. Otherwise, that sounds about right.
  5. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    You want to start with the rolling stock so in other words you need suspension, brakes, wheel/tires that way you can bolt the other stuff in hardest being the drivetrain I would think needing a cherry picker for that type of lifting.
Share This Page
