Boost Fluctuations
Discussion in '2.3L (N/A & Turbo)' started by realtripp, Apr 15, 2005.
  1. realtripp New Member
    Mar 1, 2003
    Message Count:
    212
    Ft. Madison, IA
    I have the boostvalve in my car and now I can see 15psi, but not a steady 15. The boost usually fluctuates between 13-15psi (fuel pressure goes between 53-55psi at this point).
    The instructions said to hook up the valve between the WGA and the vacuum tree. Is this the right way to do it? Could that be causing my fluctuations?
    I put the plug that was supplied into the prescribed spot and saved the old fitting. If I put that back on would that fix it?
    There is nothing that "sounds" dangerous when this fluctuation happens, I just want to pull a steady 15psi.
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Mine does it on occassion, normally I can pull the cap off, blow the crap out of it, put it back together and get solid boost readings from it...
    Remember it's a cheap manual controller, it will never be perfect.
  3. realtripp New Member
    Mar 1, 2003
    Message Count:
    212
    Ft. Madison, IA
    I will try that Stinger, but it is brand new. I took it out of the box and put it in. Still worth a shot though.
    I even checked that little bleed hole when I put it on.
Share This Page
