BOV question
Discussion in '2.3L (N/A & Turbo)' started by radartec, Apr 15, 2005.
  1. radartec Founding Member
    Jul 19, 2002
    Message Count:
    245
    Northern CA
    A blow off valve is needed vent excess boost pressure to the atmosphere when changing gears, etc. What I am wondering is for the adjustable BOV's what psi would I adjust it to if I were running 15lbs of boost? Would I adjust it to 14, 15, 16 lbs?
  2. gio_momma New Member
    Apr 1, 2005
    Message Count:
    89
    Corona, CA
    They aren't really adjustable for the amount of boost you run. The more boost you run, the harder the valve closes itself.
    If anything, you'd just make sure that the spring isn't so tight that it won't open when you lift...like if you lift and it still has some surge/flutter, you'd want to run less preload.
  3. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Generally, you adjust it so it won't quite open at idle...then you know it's as soft as it can be without causing a vacuum leak.
Share This Page
