hey folks just wanted to throw my future build on the net to make sure things will flow together. please let me know what you think!!!!
24 lb injectors
trick flow track heat intake 75 mm upper
summit 75mm throttle body w/ spacer
3/4 intake spacer
flex fan
trick flow stage 2 cam
hi comp lifters
off road h pipe
msd cap/rotor
bbk cold air intake
edelbrok victor jr heads thinking about having them shaved for higher compression?
i was wondering will i have any issues with the above setup? or anything i should sub for. i really would like to hit the 350-400hp area. my future goal is a nx n20 kit 75-100hp shot. thanks for taking the time to read and reply!!!!!!!!!!!!
24 lb injectors
3/4 intake spacer
flex fan
hi comp lifters
off road h pipe
msd cap/rotor
bbk cold air intake
