Buying an '06 GT
Discussion in '2005 - 2009 Specific Tech' started by Jholewin, Jun 11, 2008.
  1. Jholewin New Member
    Apr 21, 2002
    Message Count:
    22
    I test drove an '06 GT at a local dealer yesterday and I am seriously considering putting an offer on it. However, I'd like to know what specifically I should be looking out for regarding technical issues with these cars. My main concern is that the car has 40k miles after only 2 years. That most likely indicates a lot of highway miles, but that's still quite a few miles. Are there any known issues with the 3v 4.6L motors around this mileage I should be looking for? Or do these motors easily go 100k+ miles without serious problems?
    There are lower mileage GTs at other dealers, but the price is right on this one. For GTs with 20k miles, other dealers are asking low $20k's, while this GT is marked at $17.5 after the current rebate. Would the mileage be enough of a concern that the extra $5k is justified? The car is otherwise in immaculate condition.
    One thing I did notice during the test drive was what sounded like a clunk from the rear-end occasionally just after I came out of a turn. Is this just normal differential operation in the rear-end, or could it be a sign of trouble? I would talk with a mechanic about it before finalizing any purchase, but I'm curious what your opinions are.
    Thanks!
  2. Eric3D New Member
    Jun 11, 2008
    Message Count:
    20
    I purchased a 2006 Tungsten 5speed GT in perfect shape with 7K miles on it just a few weeks ago here in ATL. Purchase price was $19K plus tax if that helps out at all. It has nice chrome 18" factory wheels on it also.
  3. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    I notice that the rear end is clunky in turns when the rear end is still cold. It is sort of loud, but it goes away when the car gets hotter. Another thing you may or may not notice are the front struts making popping noises when going over speed bumps and stuff. That is also normal, though there was a bulliten to fix it, it is not harmful just annoying.
    Check the Alternator, those are known for going bad, and when they go bad the voltage screws up the cams VCT. Do yourself a favor and buy an extended warranty with the car.
    When washing the car, water will also leak onto the passenger side floor on a lot of these cars. That means they are missing a weld. A lot of cars have this problem.
    Is the car still stock?
    And explain this "rebate" on a used car.
  4. Jholewin New Member
    Apr 21, 2002
    Message Count:
    22
    It definitely sounded like it was coming from the rear of the car.
    Interesting, thanks for the heads up!
    As far as I know, yes. I plan on doing a much more thorough inspection, though, if I decide to pursue this.
    The dealer is having some kind of sales event, and select used cars are either $500 or $1,000 off asking price. For all I know they just added $1,000 to the asking price then "took $1,000 off." :D The KBB value of the car is $20k, so asking $17.5 before tax doesn't seem too bad.
    Do you think 40k miles is a big issue? I'm just not sure it's worthwhile to spend an extra $5k to drop 20k miles on a different car. Unfortunately, there are no service records besides what the dealer did after trade-in, but the car drove fine.
  5. klaw Member
    Oct 11, 2007
    Message Count:
    354
    The car will likely have the original two-piece spark plugs. Before you buy the car insist that the dealer change the plugs over to Champion or Brisk 1-piece plugs with anti-seize on the ground shield. If they have problems replacing the plugs, the fix will be on their dime not yours. Once the anti-seize is on, you should be good to go - especially with one-piece plugs.
  6. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    Yeah, those stock plugs are something to worry about too. Forgot about those.
  7. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    I didn't think this website was like this. The plug "problem" is not that bad as people on the internet make it seem like. I've personally done them before and it's not a big deal. Just follow the TSB procedure and you'll be fine.
  8. klaw Member
    Oct 11, 2007
    Message Count:
    354
    I changed mine myself too and it was no problem - my point is that if you're buying a used car and you have one opportunity to get the dealership to take the risk on the plug change, why wouldn't you do it? There wouldn't be a TSB if there wasn't a "problem". In terms of this "website not being like this" what are we supposed to do? Stick our heads up our butts and pretend that everything's perfect? The guy asked for (honest?) opinions not sugar coating.
  9. 281Ponies New Member
    Nov 14, 2003
    Message Count:
    190
    The plugs are a good point especially looking at a car with 40k on it… I doubt they have been changed.
  10. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    what are some good plugs to go with?
    what is the best oil?
  11. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    Oil wise I have been using the Motorcraft Synthetic Blend. I know it's not as good as Mobil 1 and Royal Purple, but it's a $15 oilchange with the Motorcraft Filter included. Pick them all up at Wal-Mart.
  12. cave diver Member
    Sep 10, 2007
    Message Count:
    82
    Champion #7989 are the only one-piece plugs in a standard heat range and they eliminate the TSB issue completely. They work great, I recommend them :nice:
  13. Jholewin New Member
    Apr 21, 2002
    Message Count:
    22
    Thanks for the information!
    I've read a few threads on the spark plug issue, and it seems to be pure chance whether or not you're going to break one (or more). Are the new one-piece Champion plugs OEM equipment for '08+? If they're not OEM, I have a hard time seeing the dealer swallowing the cost for changing them out.
  14. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    what mobil 1 could i use on my car?
  15. klaw Member
    Oct 11, 2007
    Message Count:
    354
    How badly do they want the sale?
  16. FR-S8N Founding Member
    May 23, 2002
    Message Count:
    1,311
    aren't those about $15 a piece?
  17. blbrchnk New Member
    Oct 17, 2006
    Message Count:
    269
    5w20
  18. PSYKOSTEVO Banned
    Apr 11, 2008
    Message Count:
    200
    Aren't all the plugs for our cars?
  19. cave diver Member
    Sep 10, 2007
    Message Count:
    82
    I paid $4.95 each for mine from Summit Racing but that was a mis-price and they are now around $11-12.00. I'm sure you can find them for less with a little web surfing. Even at $12.00 each they are a bargin when you consider how long they will last and that they eliminate TSB issues.
Share This Page
