Calculating injector timing
Discussion in '94-95 5.0 Tuning' started by a_k, May 22, 2007.
  1. a_k New Member
    Nov 12, 2004
    Message Count:
    172
    I'm hoping to get my car running this weekend:D and I had a question about calculating the injector timing. I have an an fti cam and when entering the exhaust events in EEC analyzer my close is 1* ATDC at 108 degree intake centerline. In the program under exhaust events it wants it BTC. Would I just put a -1 value in this box? :shrug: Also what is the best method to datalog wot runs to fine tune this table? What gear ect....
  2. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    I've been having the same dilema during the last 2 days.
    When i did my first injector timing calculations based on EEC Analyzer "original" settings
    "Initial Distributor Timing" = 10 ( i now know it sould be 0)
    I've got a 35x nearly on all rows ( with a good datalog ) , ive round them to 360 on all rows , since then the car has a really good drivability stock settings was 300 (j4j1). I honestly didnt feel any diference but what is worth i put them in there and no problems.
    But since yesterday i have been :bang: since new calculations from EA are more stock wise ( 300 ) rather 360.
    The cam specs are this ones :
    Intake Open : 1 BTDC
    Intake Closes: 37 ABDC
    Exh. Opens : 49 BBDC
    Exh. Closes : -3 ATDC
    Lift Intake: .500
    Lift Exhaust: .510
    Duration Advertised : 284 Intk. 292 Exh.
    Duration @.50 : 218 Intk. 226 Exh.
    Above Centerline 108 ( Wich says " This line will make this cam 4 deg. advanced"
    ) I dont know WTH they mean with this.
    http://store.summitracing.com/instructions.asp?File=lun-51014lun.pdf
    I am really confused with this parameters on EA.
    If some one with more experience on the Injector timing would chime in for both of us i should be really apreciated
    :nice:
    They were nice write ups on EEC Tuning, but the site right now is a toast, i hope they dont loose all the posts like when they were tweecer.opklink
  3. a_k New Member
    Nov 12, 2004
    Message Count:
    172
    Yeah I noticed that too. I usually just search around on those forums when I have a question and it usually has been answered. Any help is appreciated though:nice:
  4. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Guys
    I could not say I understand all that stuff as well :nono:
    Several years ago, many of us at that time discussed that issue for several
    days and I ended up using a value of 392 in all cells for my combo :shrug:
    I can say I found my idle was more stable and the cam lope was not
    as radical which was a blessing to my way of thinking :D
    My drivability has been quite good using that value :shrug:
    Much more knowledge has been learned by the self tuning
    community since then. I might could go over all that stuff
    again and make some improvement.
    BUT
    Doing all that is not very high on my priority list of things to do
    Of course ... that old thread was lost when they had the big
    change :( which was in name and server I suspect
    Which brings up a another thing to consider :D
    Anytime you see info that .........
    you can use now
    might use in the future
    or
    you might not understand it at the time you were exposed to it
    but
    you can tell ... its something important
    etc, etc, etc
    Set up on your hard drive a Tuning folder with sub folders for things
    such as Closed Loop Tuning where you put your files on topics like
    lambse, kamrf, adaptive, etc. You would want a folder named Open
    Loop Tuning for stuff on fuel&spark tables, high speed enrichment,
    and so forth.
    You'll end up with a database of info that will be of so much help and
    you will find as your knowledge grows ... that stuff you put in there
    that you did not understand at the time ... you now do and it is
    right there on your hard drive for you to instantly use :nice:
    Guys ... none of us can remember all that stuff :nono:
    Some of the time ... you find some really good stuff ... and later ...
    you want the info ...but ... you can't find ... or ... it was lost on
    some server that crashed :bang:
    Here is one really BIG bummer about not saving good stuff as you
    run across it :(
    Many times you guys ask about something I understand
    As a matter of fact ............. Once upon a time ..............
    Right here on this very site ................
    I gave info with charts or tables or other very detailed info
    to help others understand
    Some of that stuff took me a good while to compile for all to see :crazy:
    I don't even wanna do it all over again :fuss:
    so
    Why not point peeps to the thread as the info is still valid :shrug:
    Lots of the time ... I can't find the info :bang:
    and
    Its my own dadgum post I'm looking for :rlaugh:
    I know the info the info is on the site all right :)
    but
    Its usually buried in some thread where the topic of conversation
    had changed 180 degrees from the original posters Q
    Anyway ... if you don't build for yourself a database of info ....
    NOBODY else will ;)
    Grady
  5. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    Yes that is absolutely true , but none the less and not trying to make any comparing but the Stangnet Tuning forums are infinite more reliable than the tweecer forums, but not so full of peeps with the amount of knowledge that is on those forums.
    Absolutely no comparing since the peeps choose what forums use. But in some times is absolutely depressing to some tweecer users like us , that there is no forum so far reliable enough to trust where to find information on tweecer, i mean i can search at least 4-5 forums of mustang and will have good information on the tweecer.
    If some user of the tweecer forums reads this please chime in a post on what way we can help to recover or have online again those forums, because the forum database is absolutely needed.
    I hope many of us here are in the same boat and yould like to contribute to help those forums. :shrug:
    But ohh well back to the topic.
    Grady i am curious what make you push the injectors open at 392 , arent you dumping some fuel to the exhaust ( i dont know if your cam have some slope so this situation is worse ) but according to help on the EA , ideally you should be opening the injectors some like 2 degrees before the Intake valve starts to open to help cooling the charge.
    Grady i would like to ask another thing , I absolutely dont remember if us ( CBAZA ) have to make the calculations of the injector timing on the Start or the Stop Cycle. do you have any info on this??
  6. Guero New Member
    Oct 12, 2005
    Message Count:
    2,195
    So How important is injector timing?? Im set at stock 300 for all rows.....
  7. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Please understand ...some of the time
    You guys got a better handle on this stuff than I do :nice:
    I got started with this stuff in its infancy.
    Not much was known about ANY pcm's
    and
    Certainly not much about our 94-95 pcm's
    Heck ... Back then ... I did so much research trying to learn stuff :crazy:
    and
    Then ... When I would put it into to play :nice:
    I did not get the same benefit as all those other guys :scratch:
    Over time ... I discovered Fox and 94-95 was not the same :eek:
    Some of the stuff I've learned ... I forgot :shrug:
    Some of the stuff I've done .............
    I found the info from trial & error by looking at raw data :shrug:
    But over time I got decent drivability and WOT power :nice:
    I'm not trying to show how smart I am by saying that :nono:
    I am trying to show I wanted to learn :)
    and to do it
    I had to be persistent and not always believe or follow the masses ;)
    cause
    The masses all drove Fox Stangs :rlaugh:
    and
    Much of their info did not work for my 1995 GT Stang :bang:
    Never the less .. as I discovered and learned things ......
    I tried to share with all as I went along my journey ... you might say
    Then versions of CalEdit, CalCon, and EEC Analyzer changed
    and some peeps had issues that I was just not gonna deal with :(
    Then some of my efforts that were documented on various sites
    Well ... They were lost forever :(
    I don't always have a good reason or understand how to help :bang:
    when
    You guys wanna know why I did this or that
    and
    This inj timing thing ... its is one of those times
    I finally came to this kind of thinking and said to myself :D
    Look Grady ... Even though you don't understand all that stuff :scratch:
    You got your Stang to drive like a stocker and make good power :banana:
    Why would you wanna deal with having to know everything :shrug:
    and
    Why would you wanna subject yourself to software that
    makes you learn things all over again :fuss:
    or
    Software that makes you analyze your data differently :nonono:
    I've not kept up with the latest & greatest
    and
    My decision to do that has been done in my best interest ... IMHO
    but
    Some of the time ... I just ain't got it in me to know how to give a
    good reason for why I did something I did ... a long long time ago.
    I know you guys wanna learn
    but
    I don't know what to say except some info takes more effort to grasp
    than others.
    I do not think you are gonna find ........
    One place where all the info can be found IMHO.
    Grady
  8. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    So far i have not seen any improvements, or any goods, so unless i think you put some completely off values, i think there is absolutely no need to mess with it. i mean i barely move the injection 60 degrees advanced to the stock cobra values.
    But as i will say below, if it could improve driveability,mpg,or power i think it could be a good think to learn and give it a shot :shrug:
    I agree in some part with you , hoewever i think that if there is a little room to do some improvements why not try it!
    I think all can learn something new every day :nice: and if its for some good benefits either on driveability or power then its good to learn :nice:
    And yes indeed grady, some thing i have learned is DO NOT USE EVERYTHING you read , cause the most ppl uses FOXES and their computers work internaly very different from ours
  9. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    OK i was looking at my tuning files and all the help i gathered from this matter. and iI found the document i was talking about :
    View attachment Tuning Injector_Timing.txt
    I hope it can help :nice:
    Ohh an BTW EECtuning.org its moving to another server , so hopfully this was not a bad crash just a simple hosting problem
  10. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    I fear I did not make something clear :doh:
    When I posted ............
    and
    I was talking about me and venting a bit about being told
    things were being changed for the better and they were not.
    I was not trying to say others should not strive to learn or get
    involved with the latest trend of thinking
    or
    Choose to use the latest offering of software or hardware
    I guess I was trying to say ..........
    I got the job done to my satisfaction with ........
    "Old School" thinking and methods
    If I gotta trade known bugs for unknown bugs
    or
    Go to extra trouble and change my methods
    I'll stay "Old School" until I see others doing
    things with "Latest & Greatest" that is gonna
    benefit me
    Grady
  11. a_k New Member
    Nov 12, 2004
    Message Count:
    172
    I am also wondering this. EA defaults to the stop cycle on mine.
    :scratch:
  12. final5-0 New Member
    Apr 7, 2003
    Message Count:
    6,803
    Much talk has been made on the tweecer site about inj timing
    but
    They gotta get the site back up.
    That site is one of my buttons on the task bar I use all the time
    like the button I have to easily link up to StangNet. Those buttons
    take me straight to my desired location rather than some main page.
    Last night I went to their main page as opposed to the tuning forum
    and saw a note saying they were moving to a different server.
    When they get it back up ... I'd focus in on CBAZA users for more
    specific details.
    Grady
  13. R100RT Founding Member
    Nov 28, 2000
    Message Count:
    357
    "When i did my first injector timing calculations based on EEC Analyzer "original" settings Initial Distributor Timing" = 10 ( i now know it sould be 0)"
    Nope, use -10 in the EEC. -10 means the intial timing is 10 BTDC. 10 means 10 ATDC.
    Using the EEC timing cals will yield better milage and better idle. I couldn't tell if HP changed.
    Eric
  14. a_k New Member
    Nov 12, 2004
    Message Count:
    172
    Awesome thanks guys:nice: I'll definitely be doing alot of reading around once the site comes back up.
    edit. the site is back up:banana:
Share This Page
