Can't find!!!
Hey all I'm rewiring a new harness into my svo most of the wiring is corroded and looks like some of it was giving me problems.
but anyways i have done my searches and went to other web pages i have a couple of printouts for the turbo coupe a pinout sheet for 85-89 merkur,83-86 t-bird,83-84.5gt,84-85svo,85.5-86svo and 87-88 t-bird.
I have looked to wherever i can get some pages won't pop up or keep getting redirected not puter wiz so i'm stuck with that problem.
I'm using a wire harness from a 89 lx and just wired in the vam ive repinned the harness for the la3. T he problem i have now i have the two main connectors of the harness that hook to two other connectors at the drivers side firewall a 8 pin w/5 wires and 4 pin w4 wires old connectors.
The new connectors 8 pin 7wires 3 pin 3wires. I think i got a couple of them but i want to be sure i don't fry anything.
Wanted to know if anybody has used a different harness knows of the way to wire the new connectors up or what colors go to what?
Thanks apprecciate any help...
You need to figure out which extra computer wires are running to these plugs. Once you figure out what each of these extra wires are you then need to figure out if they even need to be hooked up. As for matching the older plugs and the newer plugs up you will need schmatics for both and compare them to ensure they go to the correct corasponding pins on each harness. I have color coded the 89 harness to make things easier to find. You can find it on my web page. 89 PINOUT If you already have your SVO pinout you have all you need to figure it out.
