car is smoking !! help
Discussion in '2.3L (N/A & Turbo)' started by dawsonsdaddy49, Oct 15, 2004.
  1. dawsonsdaddy49 New Member
    Apr 5, 2004
    Message Count:
    93
    ok i just picked up this 87 coupe.....only paid 100 bucks but still !
    2.3 / t-5 ...150k
    when i went to drive it home ...it runs rough ...kinda like it has a miss , had to use some starting fluid to get it started though. anyway the car is puffing a lil bit of black smoke. i bought it from a guy , his sons always drove it now his son is in prison or some stuff so he didnt know what was wrong with it.
    any how here is the symptoms
    runs rough
    wouldnt start without starting fluid
    runs very rich/can smell gas in the exhaust
    studders when i get to second gear like it wants to die
    black smoke in the exhaust
    any suggestions or ideas ? :shrug:
  2. dawsonsdaddy49 New Member
    Apr 5, 2004
    Message Count:
    93
  3. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,752
    78
    this forum doesn't get much traffic... be pactient!
    On a car that is new to you with no histroy the best you can do is start checking everything out.
    Make sure the ignition timing is a 10* with the spout out.
    Make sure the fuel pressure is a 39psi with the vacume line off and drops when the line is plugged back in.
    Pull the spark plugs, and see if one cylinder is way richer than another. It may have a leaky injector.
    Replace the ignition components. Who knows when the last time it got new plugs was....
    Look for vacume leaks. They generally won't cause black smoke, but you probably have some.
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Make sure the fuel pressure regulator is ok (pull the vacuum line off the top of it and see if there is fuel in it).
  5. dawsonsdaddy49 New Member
    Apr 5, 2004
    Message Count:
    93
    ok
    i will check all of those in the morning !
    what is the normal casue for black smoke coming from the exhaust ?
  6. freakintiger New Member
    Apr 9, 2004
    Message Count:
    310
    Cause for black smoke is an engine running to rich, that is, too much fuel.
  7. dawsonsdaddy49 New Member
    Apr 5, 2004
    Message Count:
    93
    humm
    so it almost has to be the fuel presure regulator or perhaps ?
    its gonna need a tune up after having run like that anyway
  8. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,752
    78
    It could be a leaky injector too, but I think a bad fuel pressure regulator is likely.
  9. dawsonsdaddy49 New Member
    Apr 5, 2004
    Message Count:
    93
    ok
    i pulled the hose off the top of the fuel regulator and nothing came out ?
    sooooo any other ideas ?
    plugs are black and sooty ( rich )
Share This Page
